on wednesday coming i am finally getting my sub fitted and amp. i am using a 800w 450 rms to run my sub and 6x9 (on tri-mode) which is all fine.
but do u think my battery will die on me using this?
thanks alot
will my battery die on me?
nathy_t
, Mar 23 2004 12:04 AM
6 replies to this topic
Posted 23 March 2004 - 12:04 AM
Posted 23 March 2004 - 12:07 AM
u should be fine IMO
depending on how loud u have it and what else u got realy
Posted 23 March 2004 - 12:28 AM
well i'll want it loud enough, as for other stuff whatcha mean?
Posted 23 March 2004 - 12:05 PM
it'll vary...if you have heaters, wipers on lights etc. then maybe....well i'll want it loud enough, as for other stuff whatcha mean?
to check your alternator is good enough.... borrow a multimeter of somebody if you can, and check that it is putting about 13 volts out with all the stuff going
if it is...your fine
if not...it'll slowly drain your battery
Posted 23 March 2004 - 04:34 PM
as long as the blue remote switch wire is connected it should be fine, i run 3 amps all off one battie and its normaly fine.
Posted 26 March 2004 - 08:40 AM
depends what amp it is as well, if its sumthin like an alpine monoblock jobbie it will amost certainly drain your battery wheras if its something like a sony explod u should be ok.
personally i am fitting another 2 batteries for my ice install!!! complete with split charging system and high output alternator!
