Tuning To My Single Point Injection Mini?
5 replies to this topic
#1 rover
rover
  • 61 posts
  • Local Club: Essex Mini club
Posted 29 September 2009 - 05:40 PM
Hi
Have just had a stage one kit fitted to my mini which is a 1993 cooper with 1275cc single point injection engine . I was told it doesnt need tuning because its a spi. Is tuning neccesary? Waste of money? Is it needed if its a spi engine?
thanks
#2 MRA
MRA
  • 7,607 posts
Posted 29 September 2009 - 08:17 PM
No need up to about 90BHP as the ECU can adapt to suit :) However always fit the bosch type lambda sensor its cheaper in the long run :)
#3 rover
rover
  • 61 posts
Posted 01 October 2009 - 05:51 PM
Hi
Thanks for the reply whats a bosch type lambda sensor?
#4 Pauly
Pauly
  • 4,213 posts
Posted 01 October 2009 - 06:11 PM
Lambda sensor controls your fuel misture and decides weather the engines running rich or lean, by reading the exhuast gases exiting through the exhaust manifold.
Paul.
#5 rover
rover
  • 61 posts
Posted 04 October 2009 - 07:21 PM
Thanks for the reply. Do you know anyway or anything that monitors the fuel consumption as the standard fuel gauges on the Rover mini's i find are innacurate and useless.
regards
#6 Pauly
Pauly
  • 4,213 posts
Posted 04 October 2009 - 07:28 PM
Fuel gauge readings are taken from the sender unit in the tank (mini fuel gauges never read right, can be fun when your on the red :)).
Paul.
