I am in the process of painting my Mk1 mini. On the underside, there are several areas where the cellulose filler primer has cracked, and these seem to only be in areas where there are tight bends, and where there are 90 degree panel joints e.g, boot floor to heel board.
Why would this be happenning? i was really careful with my prep and just a bit annoyed this is happenning. is this a common problem when using celly filler primers paints?
Whats the best way to correct this?
John
Edited by mk=john, 02 October 2009 - 11:59 AM.
