Su Hif 44 Problems
Posted 03 October 2009 - 04:29 PM
any ideas .. and your thoughts
Posted 03 October 2009 - 04:38 PM
Posted 03 October 2009 - 05:02 PM
Posted 03 October 2009 - 05:10 PM
or was the carb the only change? might just be the needle if so.
Posted 03 October 2009 - 05:19 PM
Posted 03 October 2009 - 07:17 PM
Hope that helps
J
Posted 03 October 2009 - 07:20 PM
Posted 03 October 2009 - 07:26 PM
Posted 03 October 2009 - 07:32 PM
Edited by bmcecosse, 03 October 2009 - 07:33 PM.
Posted 04 October 2009 - 10:04 AM
Posted 04 October 2009 - 10:54 PM
this is all getting strange now .. just put back on the HS4 carb and it does the same but worse .. mmmmmm me thinking now .. could it be the inlet manifold not seated right or leaking .. the car ran great with the standard exhaust and manifold with the HS4 carb .. now runs shat ... looks like im going to have to take it all off anf replace the manifold gasket and check manifold for leaks or cracks .. check timing .. etc etc .. oh the joys of motoring ... looks like me Vespa might get a airing
When the cars running try to squirt some WD under the inlet. Ive had air leaks under the inlet before
Posted 05 October 2009 - 08:51 AM
thanks again for all your replys
