I've just brought a fse PBV kit, i've read the instructions which give a general fitting guide.
Does anyone have pictures or instructions of where best to mount and fitted on a mpi cooper.
The main concern is the return fuel pipe which is metal with a swaged end and its tells you to cut to length and cap off return pipe from rail is this right?
Is it best to buy new fuel pipes to go to the rail so if you remove valve you can put it back to standard.
It just seems a little drastic to cut the ends off fuel pipes
any ideas please.
2000 cooper sport BRG,sp
Fse Power Boost Valve
jonti1275
, Oct 03 2009 05:04 PM
3 replies to this topic
Posted 03 October 2009 - 05:04 PM
Posted 03 October 2009 - 05:23 PM
See this link - PBV
You may be able to fit yours to the front nearside inner wing, just above the horn? I have a bloody great Clifford Alarm Siren there on mine so can't get it in, also I have fitted the Ultimate Engine Steady Bar which makes fitting near the Wiper Motor a tight fit also !!!
Posted 03 October 2009 - 05:42 PM
It fits as i thought it would by cutting up the return pipe, didnt get one of those niffty little gauges though.
Thanks for the reply its been a great help.
Posted 03 October 2009 - 05:51 PM
PBV didn't come with the gauge, bought it as an extra so I can be sure of pressure. Ebay have them advertised for about £5.00 (I have a spare one somewhere if you can't find one).
Suggest cutting the flexible with just enough to get a plug in the end.
