Connecting Phono Cable?
Posted 04 October 2009 - 01:04 AM
Posted 04 October 2009 - 02:24 AM
if you look at the ends there 2 tier, with usually a black piece of plastic on the connector.
so im guessing two separate wires, so many if each section is soldered correctly it should work ?
Posted 04 October 2009 - 01:03 PM
i have known phono's using twin cables within a braid, check that the twin cables are connected together or one of them may be connected to the braid.
twin cable + braid are normally used for balanced signal cables in PA use, not generally used in car audio.
Posted 04 October 2009 - 10:14 PM
Posted 05 October 2009 - 05:05 PM
i take it its a active sub??
Posted 05 October 2009 - 05:06 PM
Posted 05 October 2009 - 06:32 PM
Posted 08 October 2009 - 08:13 PM
you do have the blue remote wire connected to the head unit dont you??? and the head unit is on and playing sounds???
yep blue remote wire is connected, head unit is on and playing music but amp just flashes on then off. Its a fusion encounter thing (yes its not staying for too long)
Posted 08 October 2009 - 08:26 PM
check all wires for shorting
unplug the phono cables and see if it still kicks off
if it does
keep them unplugged and disconnect the speaker wires to the speaker
if it still does
run a new remote wire
then run a new earth
if it still does
run a new power cable
if it still does
its fooookd
Posted 08 October 2009 - 08:53 PM
sounds like the protection has kicked in.....
if it does
if it still does
if it still does
if it still does
its fooookd
Have tried it without the phono cables connected and without the speaker wires but still 1 up to the sub
Will try what you've suggested tomorrow
cheers
