Year: 86
I got Mini 1000 which runs great but wanted to switch to twin SUs mainly for aesthetics. So recently, I bought a set of used HS2s and manifold, cleaned them up and rebuilt them (new standard jets, blue springs, butterflys and shafts), set the initial mixture at 1.5 turns out. The motor started right up and runs ok except for a bit smoke (rich)and a couple of problems which are probably related...
1. The balance is way off. One carb's flowing a lot, the other hardly at all?
2. The mixture's too rich even after turning the mixture all the way in on both. When I raise the pin the high-flowing carb the idle goes up, on the other there's no change (no matter what the mixutes set at).
Any non-standard parts that might be involved with the problem?
None...
Any ideas on what would cause the balance to be off so much? (the motor was running fine with a single carb so I don't think there's anything wrong with it)....
Edited by VNOMUS, 04 October 2009 - 03:47 PM.
