Throw-out Stop
Posted 04 October 2009 - 05:00 PM
Hi Everyone,
Just finished putting the car back together after a clutch rebuild and I have one question, should the revs drop as I put my foot on the clutch pedal? It happens now and I don't want to be wearing down those thrust washers! I adjusted the nut back in until this stopped happening, but now the clutch doesn't disengage.
Is it normal for the revs to drop like this?
Rawky
Posted 04 October 2009 - 05:04 PM
but i know my revs drop slightly when i dip the clutch
Posted 04 October 2009 - 05:37 PM
(Assistent needed of course
Paul.
Posted 04 October 2009 - 05:40 PM
Posted 04 October 2009 - 05:45 PM
Posted 04 October 2009 - 05:50 PM
Posted 04 October 2009 - 05:54 PM
Rawky
Posted 11 October 2009 - 12:48 PM
Why does a bolt head have to be a certain clearance from the clutch arm, when it never comes into contact with it?
Posted 11 October 2009 - 02:10 PM
If it's a pre verto, the return stop allows you to adjust how far the clutch arm returns so it can be set so the release bearing just disengages. If it's set correctly you should be able to pull out the clutch arm by hand until the release bearing makes contact with the clutch cover, creating about a millimeter gap between the arm and bolt head.
Posted 11 October 2009 - 02:30 PM
By the way, what does the return stop actually achieve?
Ethel has answered your question but it sounds like you are focusing on only one of the two adjustments that need to be made on the external pre-verto clutch components. The stop bolt for the arm is nominally set to 0.020" to that bolt head you mentioned. It effects the amount of pedal travel you have before the clutch releases/engages and as stated above, you want it set so the release bearing is not riding all the time on the rotating components.
The other adjustment is on the BIG nut on the end of the clutch cover. That's the one that affects the thrust bearings.
Posted 11 October 2009 - 03:20 PM
These settings are important for reliability
