I was having trouble getting reverse originally (I was pulling up on the lever instead of pushing down – which would appear to be wrong on this type – Doh!
Anyway, I ended up removing the 2 operating shaft levers, and subsequently with significant frustration, time and steep learning curve have managed to achieve 1st 3rd and 4th gears. Obviously this leaves 2nd and reverse which I just can’t select. I have had 2nd and reverse on a previous attempt, so I know they work Needless to say it is a real pain, and such a shame because I’m just not getting any use of the car.
This leads to the question… Has anyone got any advice on the right way (if there is one) to set up the operating shaft levers that would allow me to select all the gears and get using this crackinig little motor?
Any advice or general encouragement gratefully received!
Thanks, David
