Starting From Cold
7 replies to this topic
#1 Fire_monkey
Fire_monkey
  • 489 posts
Posted 10 October 2009 - 11:32 AM
Model: mini 1000
Year:1991
Description of problem (please be as in depth as possible):i am having a bit of trouble starting the car on cold mornings, the engine will maybe fire of 1 cylinder then won't fire of any, then i try again and this will flatten the battery, so i will charge the battery and give it one or two more attempts and it will fully fire up..... was just wondering if something is up?
Any non-standard parts that might be involved with the problem: 12G490 head on 998 block, stage 1 kit, profiled AAU needle
#2 Pooky
Pooky
  • 5,691 posts
Posted 10 October 2009 - 11:38 AM
Old batteries hate cold mornings! Might need a new one...
#3 Fire_monkey
Fire_monkey
  • 489 posts
Posted 10 October 2009 - 11:59 AM
yer i throught that too.
but i have a newish (few years old) Halfords battery and even that seems to struggle.
#4 Loz248
Loz248
  • 47 posts
  • Local Club: Surrey Hills Mini Group
Posted 10 October 2009 - 12:10 PM
The slight drop in temperature coming up to the winter always highlights any battery starting problems but another factor is the damp in the air. Not very technical but have you tried a good dose of WD40 on the engine electrics, leads etc?
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 10 October 2009 - 01:02 PM
Suggest new spark plugs - and complete overhaul of the ignition system. Also check battery connections and earth wire connection engine to car. Also check the fan belt is tight enough to charge the battery!
#6 Fire_monkey
Fire_monkey
  • 489 posts
Posted 10 October 2009 - 01:29 PM
thanks guys will give your ideas a try
#7 jaydee
jaydee
  • 8,565 posts
Posted 10 October 2009 - 01:32 PM
Have you upgraded your coil? Fitting sports coil retaining the ballast wired feed cause this problem.
#8 lrostoke
lrostoke
  • 6,923 posts
Does sound more damp related with cylinders kicking in randomly.
I use a plastic bag tucked down infront of the engine, covers the dizzy, coil and HT leads. works a treat keeping the wet out.
