Twin Carbs On A 998 Mini
Posted 13 October 2009 - 11:08 AM
Posted 13 October 2009 - 11:29 AM
Posted 13 October 2009 - 11:42 AM
thanks very much,can i use the needles that in 998 carbs or are they different,and also how do i know if they are m/gy needles are they marked with them letters sorry if i sound thick but im only 16 and learningYou don't change the jets with SU carbs, you change the metering needles. Yes it's almost certain you will need new needles and a proper setup. If the carbs are currently built for a 1275 they most likely have M needles which will be too rich for most 998s. You should try GY needles as a starting point.
Posted 13 October 2009 - 11:46 AM
Posted 13 October 2009 - 11:54 AM
You have to match the carbs with a good breathing head (like a 295) and a good manifold (like an lcb or a cooper freeflow) to notice any performace improvement, otherwise they will only drink fuel.
Edited by jaydee, 13 October 2009 - 11:55 AM.
Posted 13 October 2009 - 01:47 PM
Posted 13 October 2009 - 06:51 PM
ok thanks can you tell me were i can some needles from,thanksThat simply isn't true. You are right that new carbs aren't going to make the engine perform any better, not noticably anyway but they won't have a serious impact on fuel consumption either. Twin carbs are not more thirsty than a single and if setup right will actually make the engine more fuel efficient.
Posted 13 October 2009 - 06:55 PM
Posted 13 October 2009 - 07:21 PM
thanks very much dan ..ill some phone calls in the morrning..i take it once ive done the needles it should run a bit better??Mini specialists, carburettor specialists, Burlen Fuel Systems, tuning specialists. They aren't hard to find really.
Posted 13 October 2009 - 07:29 PM
Posted 13 October 2009 - 09:21 PM
Posted 14 October 2009 - 10:10 AM
Posted 14 October 2009 - 11:05 AM
Posted 14 October 2009 - 12:09 PM
I wouldn't have thought they would have been very nice on the 1275 they came from with AN needles. Those needles are used with twins on a 970 Cooper S or in single carb 850s, I can see them being too rich for twins on a 998 higher up the rev range. I still think you should start with GY needles as a starting point and take it to a rolling road.
I just switched to twin HS2's on my 998 and AC Dodd recommended GY needles - suffice to say they work well.
