Where Have You Put Your Amps(pics)
25 replies to this topic
#1 MINI in Black
MINI in Black
  • 153 posts
Posted 19 October 2009 - 01:33 PM
where have you put your amp as i am struggling for ideas. So could you post some pics up please on where you have put yours :thumbsup:
#2 mike.
mike.
  • 6,176 posts
Posted 19 October 2009 - 02:16 PM
I'll be screwing mine to the bootboard kit i've got.
My old amp was pretty small so i put that in the rear bin:
Thats was pretty neat and all the wires i rooted through a hole i drilled in the bottom of the bin and one in the seat lip, so i could root all the wires well hidden.
#3 james962
james962
  • 2,677 posts
Posted 19 October 2009 - 03:22 PM
Like what Minimadmike mentioned, i used to have mine mounted on my homemade boot board:
*both sides and the base of my boot board are missing in that picture.
#4 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 19 October 2009 - 03:48 PM
*whacks out picture everyone has seen a hundred times:*
That was in my old car. Not sure where it's going to go in the new car - it's got a roll cage so might try and hide it behind the drivers seat somehow.
#5 dmdangermouse
dmdangermouse
  • 407 posts
  • Local Club: Staffs Minis
Posted 19 October 2009 - 03:49 PM
Custom boot board...
#6 MINI in Black
MINI in Black
  • 153 posts
Posted 19 October 2009 - 03:59 PM
thanks every one for your post's i was thinking of putting them in back bins but dont know yet but i carnt put them i the boot as its full of subs :thumbsup:
#7 pbrain
pbrain
  • 431 posts
  • Local Club: not yet
Posted 19 October 2009 - 04:07 PM
post your amp(s) details on here and i'm sure we can come up with more suggestions...
#8 mayfairpaul
mayfairpaul
  • 102 posts
  • Local Club: WCM
Posted 19 October 2009 - 04:19 PM
I took out the spare wheel and screwed it into the floor :thumbsup:
#9 mike.
mike.
  • 6,176 posts
Posted 19 October 2009 - 05:15 PM
Is there not a little bit of space with your subs in there? You could screw the amp to the sub box?
#10 Brams96
Brams96
  • 2,308 posts
Posted 19 October 2009 - 11:17 PM
A lot of people are forgetting the 1 unused place in a mini . . . the under side of the parcel shelf. Yes heat rises but unless you're driving you're speakers really hard it's not going to get detrimentally hot.
#11 pbrain
pbrain
  • 431 posts
Posted 20 October 2009 - 04:06 PM
you could have a hinged panel to mount the amps on and then raise up out of the way under the parcel shelf...even add a couple of fans push/pull. i had problems with a couple of amps mounted upside down...they kept shutting down from overheat, so if possible try and mount flat or horizontal (this may be an issue with my amps...other amps may have better 360' cooling)
#12 Watso
Watso
  • 227 posts
Posted 21 October 2009 - 09:06 AM
Here's what i've done (with the help of Optimise Automotive):
Just an idea ;)
#13 Brams96
Brams96
  • 2,308 posts
Posted 21 October 2009 - 09:59 AM
Damn Watso, that is tidy! Looks great. What kind of amp are you running and what's it driving if you don't mind me asking? Do you have some kind of forced cooling (fans?)
Edited by Brams96, 21 October 2009 - 10:00 AM.
#14 Watso
Watso
  • 227 posts
Posted 21 October 2009 - 01:00 PM
Cheers! There's a response I wasnt expecting! ;)
Its a Genesis Profile 5 running Focal Access Coax and Components. Have a pair of Genesis P69 Subs lined up to go under the rear seat sooner or later, but want to sort out the imaging in the front of the car first (have become somewhat annoyed with my door pods and the direction of the mid-bass). Have a looky through my profile for further info, its all there somewhere (although im useless with the controls on this site so can't say exactly where!).
There's no additional cooling as the amp chassis acts as a massive heat-sink anyway (all aluminium), but there's an additional fan in the middle under the Genesis badge that sparks up when the going gets tough (rarely!).
Watso :D
#15 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 24 October 2009 - 04:15 PM
I have mine mounted on the rear bulkhead inside the cabin. They are covered by the rear seat upright.
Don't get hot so its ideal :gimme:
Mike
