Cutting Of Body For Wheels On 85 Austin?
Posted 20 October 2009 - 08:32 PM
I recently brought an austin mini city 85 and wanted to add 13" deep dish wheels. It came with 12"x5 standard with standard tyres not low profile. My tyres have about 2" clearance on front and back, in front qnd behind the wheels atm.
Many people said id get away with the 13"x7 easy with low profiles but im unsure. I have read most forums but still not sure. I would like to keep the car as original as possible for resell value as is all original and in mint condition. Can anybody who knows please help me!!! Thanks
mark
Posted 20 October 2009 - 08:33 PM
Posted 20 October 2009 - 09:32 PM
Posted 22 October 2009 - 08:36 PM
Okay thanks erm do you know which arches would be easiest and best for them? Either group 5 or sportpack?13's aren't the problem it's going over 5 inches wide that means you need to cut
mark
Posted 22 October 2009 - 09:05 PM
Posted 09 November 2009 - 10:45 PM
Can take a picture if it helps
thanks
mark
Posted 09 November 2009 - 11:47 PM
You do not need to cut at the back of the arch.
I have group 6s, but group 5s or sportspack will also do, depends on what you like the look of the best.
Posted 10 November 2009 - 11:37 AM
would it be a good idea to get a garage to do it?
this is the only thing i was majorly worried about.
the first is a photo of the rear arch and there is some sort of bracket that is rather close to the wheel.if need bee is it safe to possibly grind away abit of it to make a bit of space?
second photo is or the front wheel and arch just so u can see.
third photo is the whole car just to aks for an opinion on which arch would suit itnot sure about sport arches really but just not sure what to get ?
thanks mark
Posted 10 November 2009 - 12:25 PM
Posted 10 November 2009 - 01:01 PM
Hope this makes sense
Pete
Posted 10 November 2009 - 05:11 PM
im not planning on doing it soon just in a couple of months time wen ive got enough money for the wheels so if i find problems ill let you know
thanks guys
mark
Posted 10 November 2009 - 06:21 PM
Hope that makes sense
Paul.
Edited by Pauly, 10 November 2009 - 06:22 PM.
Posted 10 November 2009 - 09:22 PM
Posted 10 November 2009 - 11:30 PM
Thats exactly what i ment lol but you explained it alot betterYou dont need to weld anything back on if you do it properly, mark out with templates or by eye, the arch line on the wing, then with tin snips cut vertical slits every inch or so to the marked line where your going to trim, then fold the metal upwards on the line you just drawn then trim off access metal on the edge.
Hope that makes sense.
Paul.
Pete
Posted 11 November 2009 - 04:04 PM
will try and remember when it comes to it.
will post pictures up wen ive done it.
mark
