Difference In Clutch Plates?
Posted 21 October 2009 - 04:37 PM
Was wondering what is the difference between these two clutch plates?
Linky 1
Linky 2.
Also I am leaning towards a pre verto set up and have been told to go with an orange cover and a rally clutch plate. Will this be fine for everyday use?
Lastly I believe my engine is on a standard bore and it needs a rebore. Is it safe for me to assume that a rebore +20 will be okay? Im asking this as I want to order the pistons before I take the block so I can have the pistons fitted to the rods at the same time etc
Posted 21 October 2009 - 04:50 PM
Posted 21 October 2009 - 05:36 PM
Also the engine will be putting out around 70-80ish bhp so do I really a rally plate?!
I doubt it. Why not just go for the Cooper S/Metro Turbo spec plate? It's a darn sight cheaper!
http://www.minispare...=...D AND FAS...
Posted 21 October 2009 - 06:37 PM
In answer to your first question, the second plate shown is a stronger version for really hard use.
Edited by Sherlock, 21 October 2009 - 06:38 PM.
Posted 22 October 2009 - 09:01 AM
Linky..
Am I right in thinking the clutch plate included is the same as this one?
Linky..
It also comes with a blue diaphragm, can I use this or should I go for orange? The car will be in everyday use. I've read one of Calver's articles and it says
BLUE - Fitted to all big-bore engines and all Cooper S’s. This is more than adequate for most road cars, even up to 1380/1400 units putting out 110bhp.
ORANGE - Classed as the Rally/Race type, and the first of the non-standard types. Use on serious road burners developingover 110bhp, and stroker motors producing monster torque over 95lb ft. Advisable to use rally/race clutch plate if this is the case.
Basic specs of the engine Im thinking of is 1293cc, Stage 3 head, Sw5 cam
Edited by GreaseMonkey, 22 October 2009 - 09:02 AM.
Posted 22 October 2009 - 12:30 PM
I've been told that a Blue spring/clutch cover instead of an Orange will be more than fine for everyday use with the expected power from specs. Is this the case?
Edited by GreaseMonkey, 22 October 2009 - 12:30 PM.
Posted 22 October 2009 - 12:32 PM
130hp every day use....
Posted 22 October 2009 - 01:05 PM
Posted 22 October 2009 - 01:25 PM
Hi,
Linky 1
Linky 2..
That would be the set up I would run, and did run in my 1380. Nice road going, not like an on/off switch like the harsher stuff. Will also cope better than any of the standard kits when you are a bit more agressive with it
Your block would have to be pretty bad not to get away with a +20 rebore.....
The rally plate and orange cover?
Edited by GreaseMonkey, 22 October 2009 - 01:26 PM.
Posted 22 October 2009 - 01:27 PM
Posted 22 October 2009 - 01:28 PM
