Why Don't My Indicators "tick"?!
14 replies to this topic
#1 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 21 October 2009 - 07:50 PM
Good evening, ladies and gentlemen. For a while now I have been wondering why my indicators, or to be more precise the flasher unit, doesn't "tick" like most cars. I swear other mini's I've driven have done so.. I have had two different flashers, both the same. I think I have the m3 onwards type. I have mk2 rear lights, no side indicators, and little clear morris minor sidelights with orange bulbs as indicators.. Not the ideal setup I know.. Any help would be great :- Oh and the car's an "89 mayfair originally.
Edited by panelbeaterpeter, 21 October 2009 - 07:51 PM.
#2 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 21 October 2009 - 07:54 PM
is it that you do not hear the flasher unit? or the bulbs are not flashing?
it could be that you are installing a flasher unit for side indicators (if the bulbs are not flashing)
#3 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 21 October 2009 - 07:55 PM
It's made up of a bimetallic strip inside that makes and breaks the connection which in turn makes the indicators flash (usually makes a sort of quiet boink noise :teehee: ), modern ones use an electronic relay which clicks loudly as the terminals are pushed back and forth inside the flasher relay with an electromagnet
I think i've taken too many things apart over the years :-
Edited by cambiker71, 21 October 2009 - 07:56 PM.
#4 Pooky
Pooky
  • 5,691 posts
Posted 21 October 2009 - 07:57 PM
Maybe it's different makes of flasher unit. My Mini ticks a lot louder than my gf's Mini.
How's your flasher unit mounted? Maybe fitting it to a bracket screwed to the bulkhead will 'amplify' it?
#5 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 21 October 2009 - 08:08 PM
The main ticking noise comes from it bieng mounted on the bulkhead metal to metal I believe.
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 21 October 2009 - 08:16 PM
Ah.. I have a non genuine one, you can't get the geuine old type that mounted to a bracket any more. It makes no noise whatsoever, and during the day I often leave them on by accident because I can't see them due to my steering wheel/seat position. I'll try the non side indicator type one, and mount it somehow, I'm thinking a massive home made P clip!!
#7 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 21 October 2009 - 08:19 PM
I've got one thats not attached, just hanging on its wires & its just been taped to the bulkhead but you can hear it!
#8 j0-rdan
j0-rdan
  • 285 posts
Posted 21 October 2009 - 08:24 PM
Please keep this topic updated, I would be very interested to hear if it works as I have the same problem.
#9 Foxy10
Foxy10
  • 387 posts
  • Local Club: Crewe's Missiles
Posted 21 October 2009 - 08:25 PM
and me!!
#10 cambiker71
cambiker71
  • 1,050 posts
Find one in a breakers from a modern car with three terminals add an extra earth wire to it and you'll have loud clicks, also flashers that work at a constant rate too rather than the often haphazard old style ones.
EDIT
terminal wiring for modern flashers
#49 is the 12V power. (ignition feed)
#31 is a Ground.
#49a goes to the signal switch. (to indicator switch)
Edited by cambiker71, 21 October 2009 - 08:28 PM.
#11 captainjack15
captainjack15
  • 3,925 posts
Posted 21 October 2009 - 08:26 PM
Mine tick! :-
But it's so quiet, I can only hear it when I listen for it!! :teehee:
#12 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 21 October 2009 - 08:52 PM
EDIT
#31 is a Ground.
Brilliant! May seem like a stupid question, but how do I determine which is the flasher unit? I know of a Renault clio and a BMW 318 I can maybe "borrow" one from.
#13 cambiker71
cambiker71
  • 1,050 posts
Posted 21 October 2009 - 08:58 PM
EDIT
#31 is a Ground.
It's usually got flasher or 21w +21w or something similar, like this one on ebay
http://cgi.ebay.co.u...=item3eecb4bdbf
Sometimes they're a little bit taller than this one too
#14 cambiker71
cambiker71
  • 1,050 posts
Posted 21 October 2009 - 09:00 PM
If it has 4x21w on it somewhere then it could also be used in the same way to replace the hazard flasher unit, done all my minis like this.
#15 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 21 October 2009 - 09:02 PM
Cool! that's a great help thanks :-
