Hazards Not Bright Enough.
9 replies to this topic
#1 aston19uk
aston19uk
  • 510 posts
  • Local Club: no pub mini club
Posted 22 October 2009 - 11:47 AM
My harzards work when turned on. But they not bright enough . You can bearly see them. There quite dim. When i turn my indicators on, there very bright so theres no issues over the bulbs. Any ideas?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 October 2009 - 11:49 AM
is the fuse nice and clean ?
#3 Ethel
  • 26,088 posts
Posted 22 October 2009 - 11:50 AM
They share the same wiring downstream of the hazard switch. rusty contacts on the flasher under the bonnet seems most likely. How's the interior light - it shares the same fusebox supply.
I deleted the other topic.
#4 aston19uk
aston19uk
  • 510 posts
Posted 22 October 2009 - 10:15 PM
I ve never had an interior light. Which fuse is it? The fuse box is a month old and fuses are quite new, along with all the flashers units and switches. how ever the rusty contacts under the bonnet like you suggested may be the problem so id try that and let you know.
#5 aston19uk
aston19uk
  • 510 posts
Posted 25 October 2009 - 04:36 PM
i cleaned the connections up at the hazard flasher and no change. Any other ideas or connections?
#6 Ethel
  • 26,088 posts
Posted 25 October 2009 - 04:47 PM
It could be the hazard switch or the flasher itself. You could also trace the wiring back to the fuse, it should be the same colour wire and you'll know you've got the right one if the hazards stop when you pull it.
Just bridge the flasher socket contacts with a bit of wire/paperclip - the bulbs should light brightly but not flash if it is a faulty flasher unit.
#7 aston19uk
aston19uk
  • 510 posts
Posted 25 October 2009 - 04:57 PM
the flasher is new. hazard is new. id give it a go tho/ does it matter which way the flasher is plugged in?
#8 Ethel
  • 26,088 posts
Posted 25 October 2009 - 05:20 PM
It should only be possible to plug in 1 way round. It is a hazard flasher?
#9 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 25 October 2009 - 05:24 PM
you could have a bad hazars switch giving a very high resistance when switched on, hence, dim bulbs, try a different switch too
#10 jkjaxor
jkjaxor
  • 331 posts
Posted 25 October 2009 - 05:50 PM
check the connections inside the fuse case, these can easily corrode and cause bad connections,
