Starter Motor
4 replies to this topic
#1 tiganlea
tiganlea
  • 54 posts
  • Local Club: Nottsminiclub
Posted 25 October 2009 - 06:25 PM
is a 1275 auto starter motor diffrent to a manual 1275 engine
#2 MRA
MRA
  • 7,607 posts
Posted 25 October 2009 - 11:39 PM
the only differences are the types that are common between A+ and Pre A+ manuals...... ie. Pre A+ manual and auto are the same ...... A+ auto and manual are the same >_<
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 25 October 2009 - 11:58 PM
The change of starter motors wasn't concurrent with the change from A series to A+ engines. It was in 1985, Minis made before that use an innertia starter and Minis made after use a pre-engaged. There is no difference bewteen auto and manual starters of the same type though as Martin says.
#4 tiganlea
tiganlea
  • 54 posts
Posted 26 October 2009 - 08:09 PM
so the 1993 auto starter will fit the 1275 metro engine im fitting in my mini
#5 MRA
MRA
  • 7,607 posts
Posted 29 October 2009 - 07:06 AM
That's correct, 85 was a change point.... I guess what I should have said....... is if the starter ring gear on your flywheel is the same as that on your convertor then it will work ok together :D
Rule of thumb count the teeth,
129 = Verto or pre-engaged type
108 = Non verto or inertia engagement, however I have seen some pre-engaged starter motors that fit the pre-verto, they are about the same size as an inertia type and very rare :dontgetit:
