Inner Rear Wheel Arches
11 replies to this topic
#1 Jasonxpp
Jasonxpp
  • 11 posts
Posted 26 October 2009 - 04:25 PM
Hello, we are new to this forum, my son having just bought a 1990 mini off ebay which supposedly had all the welding done, can anyone tell me if its possible to replace the inner rear wheel arches without having to remove the outer panel? and the same with the repair panel on the inner wing where the door hinges bolt on? I think my mig welder is going to be working overtime!!
Thanks Mike
#2 Calman
Calman
  • 1,674 posts
Posted 26 October 2009 - 04:43 PM
Pics help by the way :D
The rear arches in not sure about but the front pannel i think you on about is either the a-pannel or the flitch. The Flitch is a wing off jobby and the a a-pannel i think you can get away with witout taking other pannels off.
#3 akaflash
akaflash
  • 96 posts
Posted 26 October 2009 - 05:23 PM
Thanks Mike
rear archs are a pain to fit, you can do them without removing rear quarter just makes a difficult job harder
#4 Jasonxpp
Jasonxpp
  • 11 posts
Posted 26 October 2009 - 07:00 PM
Thanks Mike
Thanks, its the flinch that will need replacing, I thought the wings might have to come off, its a shame as they are both new and the car has had a decent respray
#5 Jasonxpp
Jasonxpp
  • 11 posts
Posted 26 October 2009 - 07:13 PM
Thanks Mike
I've added some pics, hoe he could say there was not rust I don't know, it looks like he removed the a panael on the driverside and platted the flinch and removed the wing and a panel on the passenger side, again he platted the flinch but did'nt put a hole in for the air vent before replcing the panels!
#6 jack_marshall
jack_marshall
  • 2,540 posts
Posted 26 October 2009 - 07:19 PM
Why would somebody not mend it properly and put a nice coat of paint on like that?
Crazy.
#7 samsfern
samsfern
  • 5,243 posts
Posted 26 October 2009 - 07:31 PM
personally for the inner arch, id cut the rusty bit out,weld a new plate in, then use a wirebrush on a drill to clean the arches before painting them, im pretty sure you can access this area from inside the boot, its structural because its near the shock absorber
#8 wassupcrew
wassupcrew
  • 502 posts
Posted 26 October 2009 - 07:53 PM
rear wheel arch you can do without taking the quarter panel off. its easier if you do the whole arch with susension mount not just the outer half but easily done. whe fitch panel you can do just by taking the a panel off. leave the wing on. the hole for the air vent he's oviously just plated over instead of getting a repair panel. i've just done these on mine and the panels were only about a tenner and so easy to fit then.
#9 Jasonxpp
Jasonxpp
  • 11 posts
Posted 26 October 2009 - 07:55 PM
Thanks Mike
The picture of the inner arch shows just one of the holes, there's a bigger one near the edge
#10 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 October 2009 - 08:23 PM
inner rear arch use the bmh panel and cut to suit and weld in, if arches are going on the car then no need to repair rear qtr, front inner wing a bit more difficult
dave
#11 Jasonxpp
Jasonxpp
  • 11 posts
Posted 27 October 2009 - 01:27 PM
In what order would you suggest I fit the flinch, inner sill and front floor pan? I was thinking sill, flinch then floor pan
#12 wassupcrew
wassupcrew
  • 502 posts
Posted 27 October 2009 - 06:54 PM
i would personally do the fitch first then the floorpan and sill last just cut them out one at a time and weld the new one in before going on to the next. this wya you keep the strength of having most of the panels in place especially the sill which creates a lot of the strength of the body
