Box Sections
23 replies to this topic
#1 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 29 October 2009 - 07:08 AM
morning (too early! :D )
just a quickie about box sections.
picking up my mini on saturday and want to make sure it lasts in its current condition: i wondered if anyone would be so kind as to list all the box sections i need to spray waxoyl in and how to reach them!
also, re: the floor, what do you guys do to that horrible sound proofing stuff that is stuck all over the floor? i cant see the condition of the actual pan without getting it up, but dont want to reck my car! also what do you put down again afterwards!
cheers, T
#2 Sherlock
Sherlock
  • 654 posts
  • Local Club: Mini Register
Posted 29 October 2009 - 11:57 PM
Starting at the front: The small box sections in the front panel where the subframe mounts are, accessed through the access hole in the front panel.
Bonnet stiffeners, particularly the front ends, accesses through various holes in them.
Scuttle corner box sections, access from engine compartment, there is a gap between scuttle & inner wing.
A-posts, access via hole where door check bracket operates.
Front sill sections, best to drill a hole in each section fore & aft of the jacking point & fit grommets afterwards.
Seat mounting box section, access through holes already there.
Doors, remove pockets, if fitted & release bottom of door card.
B-posts, there is a black plastic cover, facing the rear of the car which can be removed & you can spray into there.
Side-bins & rear sill sections, remove trim from sidebins & spray waxoyl liberally into the rear heelboard end & down the side panel, There is also a sill box section in there & with a waxoyl extension probe, you can get to that from the hole drilled in the sill section behind the jacking point.
Rear wheel arches, not exactly a box section but it's important to allow waxoyl to run all around the inside where the arch meets the side panel.
Inside boot, small box sections where rear bulkhead, boot floor & wheel arch all meet, access through holes already there.
Boxed ends of rear valance, if it's original & 1980-on you can access the right hand one through a hole in the corner of the boot floor where the rear fog light wires run. Left hand, remove grommet beneath bumper which covers the hole for a second rear fog mounting.
Stiffeners in bootlid, via gaps between stiffener & skin, put plenty at the bottom of this.
As regards the sound deadening material, I remove it with a sharp chisel, working along a line about an inch at a time, by tapping the chisel vertically down on to it, it just splits away with no damage. I removed some of mine, but the original black panel primer was still immaculate under it after 28 years. I replaced what I had removed with 2 coats of Hammerite.
#3 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 30 October 2009 - 12:36 AM
that ther be a long list!!!!
#4 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 30 October 2009 - 07:10 AM
thats amazing!! thank you very much!
im not 100% what all those sections are, or how to get to them, but ill work out what i can and get back to you!
cheers! Tom
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 30 October 2009 - 12:32 PM
There are also other places, although not box sections, that you should pay attention to. These are usually good mud and dirt traps and whould be cleaned regularly and treated with waxoil:
Wing and front panel seam below headlights
Top front edge of wing above headlights
A panel to flitch panel join
Wing to scuttel join
Rear scuttle to boot floor join
Rear subframe front mounting points
#6 Sherlock
Sherlock
  • 654 posts
Posted 30 October 2009 - 06:04 PM
cheers! Tom
You're more than welcome, I was lucky, when I bought my current Mini, it was 5 years old & had been waxoyled from new, it's now 28 years old & I've repeated the treatment a few times & the structure is still original & sound. I've only replaced the rear frame & o/s front wing & A-panel. If you need any more help, please ask.
#7 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 16 November 2009 - 01:11 PM
hey again!
that list is amazing....but i dont know how to get to all (most) of the box sections!
i wondered if anyone would be kind enough to write out how to do this- i think this would be a valuable resource!!!
also, how 'much' waxoyl etc needs to go in. obv with some of them u dont know how much uve sprayed -eg inside the sills.
thanks again!
Tom
#8 Sherlock
Sherlock
  • 654 posts
Posted 16 November 2009 - 08:30 PM
hey again!
thanks again!
Tom
Hi Tom, I will get something together for you, if possible with a few photos, will take a day or two, though. Sorry for the delay, it's been too dark when I've been getting home, so I'll do it at the weekend.
Edited by Sherlock, 20 November 2009 - 03:35 PM.
#9 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 16 November 2009 - 09:59 PM
oh wow thats amazing! that'd be ideal! thanks a lot! just want to do best job i can protecting it
#10 samsfern
samsfern
  • 5,243 posts
Posted 16 November 2009 - 10:05 PM
in my opinion the best way of removing the soundproofing crap is with a heat-gun and scraper/chisel, then wipe it with petrol or thinners, carefully though, wear gloves as well...
#11 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 21 November 2009 - 12:14 AM
Tom[/quote] Hi Tom, I will get something together for you, if possible with a few photos, will take a day or two, though. Sorry for the delay, it's been too dark when I've been getting home, so I'll do it at the weekend.
[/quote]
hey~!
you had any luck with this yet?
#12 Sherlock
Sherlock
  • 654 posts
Posted 21 November 2009 - 01:41 AM
Tom
hey~!
The weekend is here, I'll be working on it.
#13 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 21 November 2009 - 10:55 AM
thanks sherlock....im relying on your investigative skills! ha ha
#14 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 21 November 2009 - 05:32 PM
Waxoyl this stuff really is horrible but works, trying to decide what to do with this regarding my project, was tempted to stone chip the underneath and waxoyl in my sills and subframe front box section also under scuttles. any opinions?
#15 Sherlock
Sherlock
  • 654 posts
Posted 21 November 2009 - 11:41 PM
Elementary my dear Watson!
