What Size Overbore And What Pistons?
Posted 03 November 2009 - 09:07 PM
I am new to this forum and have been watching it for a while. I have found some very great advice so far and for the first time the search function has drawn a blank for me.
I am currently building an A+ 1275 engine and have it completely stripped ready to be machined. My questions are:
1. What size over bore? Do i go to 1340 or 1330 and how many thou is that over?
2. Any recomendations on pistons to use / places to look for them?
3. How do i determine a good compression ration? Fuel here is 98 octane (best) and in the long run i am planning to supercharge it.
Any help would be truly appreciated.
Thanks again!!
terry!
Posted 03 November 2009 - 10:05 PM
Being as your looking to supercharge in the future, I would say you would be best off going with the smallest re-bore possible that will clean your bores up, so +20thou-1293cc if possible, then +40 thou etc. 1330cc is +60 thou re-bore, and i think 1340 is a rather special one in that it is a de-stroked 1380?! not sure on that one except that it isn't acheivable on a standard re-bore. The extra cc gained from going straight up to the bigger re-bores though will not gain any noticable extra power and just results in less potential future rebuilds. Plus it will be easier to keep the compression at the lower levels required when supercharging, i.e. less cylinder head work. I'm pretty sure minispares sell suitable pistons in all oversizes and in different dish volumes to achieve the compression desired. The compression ratio needed would depend on the boost pressure your going to use, with bigger boost pressures you maybe looking as low as about 7.5:1. It would be wise to use a programmable ignition conroller such as the megajolt so that you have tight control over ignition timing and reduce the likelyhood of detonation. This may also allow you to use more compression without causing problems especially if your going to use 98 fuel..
Sure someone will be along with more detailed info and experience soon but hope this helps a bit.
Posted 04 November 2009 - 03:53 AM
Posted 04 November 2009 - 06:54 AM
+30 - 1301
+40 - 1310
+60 - 1330 ( or as some call it 1340 but it's not )
73mm - 1360
73.5mm - 1380
74mm - 1400
Depending on your budget, go for 21251 (LC) or 21253 (HC) pistons on the over sizes... however how confident are you about the supercharging actually happening... basically as you have a choice later to lower the base compression of the engine by fitting either or all of, new pistons, modified head and possibly a decompression plate...
So my suggestion is build the engine for what you want to do with it today, and not what you may do with it in the future.
Posted 04 November 2009 - 07:31 AM
Thanks!
Posted 04 November 2009 - 07:56 AM
The Pistons are Hepolite AE ( std replacement pistons )
21251's are low compression variants eg http://www.minispare...ty=pb&pid=37695
21253's are High compression variants. eg http://www.minispare...ty=pb&pid=37864
21253's are a better piston and run as standard @ 9.75:1 which is close enough, but a skim off the top of the block with quickly raise the CR
If it's your first time build then I would suggest taking the short engine to a respected mini engine builder who should know all the necessary machining dimensions to achieve a 10:1 CR with either set of pistons, however these may be a little sparse in NZ.
Posted 04 November 2009 - 08:04 AM
dave
Posted 04 November 2009 - 09:42 AM
Dave, you said the cheaper pistons have a shorter lifespan. how short are we talking? Does that imply that the expensive ones will last the entire life of the engine and the cheaper ones wont?
Thanks again guys for all your help! I truly appreciate it and any more to come!
Posted 04 November 2009 - 12:24 PM
However, I would never use a 21251 on a forced induction engine. For forced induction Omega do an excellent piston with a 10 cc dish. I've used them on a Turbo car running 7.5 psi boost and it's good with about 115 bhp at 5600 rpm.
To go from standard induction to forced induction requires a significant dropping of the comp. ratio. To achieve this you can open out the chambers in the head by the required cc's, change the pistons for ones with a lower gudgeon pin height or a bigger dish, or a combination of all these things.
Once your engine is built without forced induction, it's easier to improve the power by 'normal' tuning methods, although that won't give the better flexibility and mid-range torque that, say, a good supercharger will.
It's a personal thing really and you just make your choice. Some feel that a supercharger is better on a Mini than a turbo-charger, just because the supercharger runs cool, whilst the turbo has lots of heat involved with it and it can be difficult to get that heat away from under a MKini bonnet. Both can be made to work well though, so again, it's just personal choice.
Posted 04 November 2009 - 05:48 PM
Posted 05 November 2009 - 02:11 AM
Seems like I will go with the 21253 - 60's (Going for a 1330cc). No other brands I should consider or is it just not worth it for a daily road vehicle?
Im looking for something that will have a kick but im not planning to race it. Is MiniSpares the place to buy from or are there any other options?
So far ive found - minispares, minisport and minimania. I have to ship them to NZ so more than anything im looking for best shipping prices
Posted 05 November 2009 - 09:15 PM
Posted 26 June 2013 - 12:42 AM
I have just been suggested to by a mini shop here in NZ that Hypatec pistins are also a very good consideration. Does anyone have feedback on these? How do they compare to the 21253's?
I have used Hypatecs in high performance engine builds for many years, they are a good piston. They come with a Hastings ring pack, these are imperial width unlike the AE ones which are metric. Their oil rings work much better than the AE ones. Available from www.minisport.com.au or www.minis.com.au in +.020 +.040 +.060 73mm and 73.5mm sizes, [however right now they are both waiting on stock to come in for the 20 40 & 60 ones.] EDIT they are now back in stock.
Another good piston is the Russell Engineering ones, which come in 72.5, 73.0, 73.5 and 74.0mm sizes. These come with a Nippon ring set (same width as the Hastings) and have the rings a little closer to the crown than the Hypatec.
Hypatec is better if building a stroker. Both pistons have a thick crown so can be decked lots if needed.
Contact russellengineering [at] bigpond.com for info on his pistons.
Both the Hypatec and Russell Engineering pistons are a 12% silicon alloy.
Edited by drmini in aust, 26 June 2013 - 12:31 PM.
