Flywheels and Cranks?
10 replies to this topic
#1 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 10 October 2005 - 05:46 PM
Right then, I have a 998 A+ that is fitted with an Ultra Light flywheel (well a lightened and balanced one at least).
Will this fit onto my A+ crank?
Furthermore, will my A+ crank fit into the A series block I am getting???
Or is it gonna be a case of getting a decent A series crank for the A series block and then another decent flywheel? :w00t:
#2 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 10 October 2005 - 06:54 PM
I would think that it will fit on the A+ crank (A+ to A+),
but i dont know about the A+ to A (crank to block) :erm:
(oops i havent been any help) :w00t:
#3 Jammy
Jammy
  • 25,397 posts
Posted 10 October 2005 - 06:58 PM
I'm not certain on this but isn't there something different about the gear that goes on the end of the crank?
*Sits back and waits for a doctor to set him straight*
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 October 2005 - 06:56 AM
hmmm, I need to think about the wallet again, don't erally want to have to buy a new flywheel and crankshaft!!!!! :saywhat:
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 October 2005 - 08:51 AM
Yes it will all fit... as long as the A series block is a 998..
Cranks are not the same between small bore (998) and big bore (1275)
and the nose of the crank is the same on ALL cranks.
#6 ed4ran
ed4ran
  • 2,849 posts
Posted 11 October 2005 - 09:13 AM
I think he wants to put it on the 1400 hes getting. :erm:
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 11 October 2005 - 09:30 AM
I want to be like GW when I grow up! He knows his onions! :w00t:
I want to use the flywheel off my 998 A+
plonk it onto my 1275 A+ crankshaft
and slap the lot into a 1400 A series block
So from what GW says, the nose is the same, and the 1275 A+ crank will fit the 1400 A series block. COOLIO!!!!
#8 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 11 October 2005 - 06:49 PM
A 998 flywheel will fit any crank, but a 1275 crank in a 1400 engine will need to be stroked unless your going for a 1380.
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 October 2005 - 06:52 PM
or as I found out a few weeks ago... it's got 74mm bores..
#10 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 11 October 2005 - 10:58 PM
1430 uses the 83mm stroked crank at 74mm bore
And if you can afford the 86mm billet crank 1480cc is poss
#11 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 12 October 2005 - 06:27 AM
Yeah, as Guessworks says, it has 74mm offset bores, so with a standard stroke crank it should be somewhere in the region of 1400 (1399 or something).
Going to get the block and pistons on Saturday afternoon from Northampton, then I will have more of an idea of what else is needed for the build.
I need to fit the pistons (that have the gudgeons with em) onto my rods too. It's not something I've done before but I have read the guide in FAQ and don't mind having a go!
Got to buy myself a new ring compressor though as the other one seems to have gone walkies! :nugget:
Unless I use the old sheet of tin and big jubilee clips trick that my old boss taught me! :)
Glad I am OK to use the old flywheel and crank, should be good fun building it all up, just need to buy those transfer gears and a good clutch.
