Dashboard Switch Illumination.............anyone Done It?
2 replies to this topic
#1 MiniSpannaz
MiniSpannaz
  • 11 posts
Posted 06 November 2009 - 07:10 PM
Was thinking about buying the kit to illumiate the switches on the dash (light switch, hazards etc) when the side lights are on. Has anybody got the kit? fitted it?? or know what exactly it does do. In that i mean does it light up the light switch itself as that is flat black front, i can see that the others would not be too difficult, but it's usually that one that i fumble around to find?? Was thinking of doing it so it illuminated the switches when the ignition was on.
#2 mab01uk
mab01uk
  • 12,504 posts
Posted 06 November 2009 - 08:10 PM
From Minispares:
"illuminates your dash switches this upgrade kit will alow the brake test switch, rear screen heater switch, fog light switch and hazard warning light square type switches to be illuminated when the main lights are on. It will also sound a reminder chime when the door is opened when the lights are on and the ignition off, which helps avoid leaving your lights on and running the battery down."
Wood and Pickett sell the same kit and a Headlamp / sidelight switch that lights up:-
Dash illumination kit - 1976 - 1997
Now back in stock after a long absence. These kits are fantastic, in that they illuminate the switches located in the centre switch panel. No more fumbling about in the dark for your heated rear window....... Available in kit.
http://www.woodandpi...cs/lighting/76/
Dash illumination kit, 1997 on
These kits are fantastic, in that they illuminate the switches located in your Minis centre switch panel. No more fumbling about in the dark for your heated rear window switch...... Available in kits.
http://www.woodandpi...cs/lighting/77/
Headlamp switch, illuminated, 1976 - 1997 Part Reference: WPA9061X
This switch is the same size as the standard one but illuminates when switched on. Can be used in conjunction with our Dash Illumination Kit. £12+VAT
http://www.woodandpi...cs/lighting/78/
Edited by mab01uk, 06 November 2009 - 08:30 PM.
#3 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 06 November 2009 - 08:16 PM
i installed the kit a few years ago and it took less than an hour.
just remember to do one switch at a time so as to not get the wires confused, although i did do it without a wiring diagram as it was missing from the kit.
also if you can, pick up the side/dipped light switch from huddesfield as the one i bought from them had a light window(unlike standard ones) which i wired to come on with the ignition. you'd be amazed how much of a differnece it makes knowing which swith your pressing
