Sill Replacement/patch
Posted 07 November 2009 - 02:11 PM
Same story on the other side.
I got a quote to have it plated, both sides, inside and out. £150 a side.
Too me this seems quite pricey, especially as it is just plating, granted he is removing the old sill, and in effect fabricating a new one, but just half of it.
The garage seem good, have just done a good looking full resto on a TR 6. But are they asking too much ?
If anyone knows anywhere in the Hertfordshire area or anyone who would do this work i would be hugely grateful.
Posted 07 November 2009 - 02:13 PM
Posted 07 November 2009 - 02:28 PM
Posted 07 November 2009 - 02:54 PM
Posted 07 November 2009 - 06:18 PM
Posted 10 November 2009 - 05:46 PM
Its a 1997 MPI
Posted 10 November 2009 - 05:50 PM
it's not difficult and will save you ££££ in the future
Posted 10 November 2009 - 06:02 PM
if your a mini owner you really need to teach your self to weld
Amen!
Posted 10 November 2009 - 06:09 PM
I am hoping to learn to soon. But student at moment and dont really have the money to afford a welder or the means to practice.if your a mini owner you really need to teach your self to weld
But working on it
Posted 10 November 2009 - 06:10 PM
If i am replacing my cills, due to small rust holes on both sides. What parts do i need. I am very new to the mini scene.
Its a 1997 MPI
Just the sills themselves, plus a sheet of steel might come in handy to fill the holes you'll need to repair before you can put the sills on!
Are you doing these yourself?
Posted 10 November 2009 - 06:19 PM
But working on it
£300 it looks like the buy a welder option is cheaper already
Posted 10 November 2009 - 07:10 PM
But working on itI got a quote to have it plated, both sides, inside and out. £150 a side.
It does seem that way. But would rather not learn to weld whilst trying to fix my sills.
What sills will i need to purchase for my mini, are these correct ?http://www.minispares.com/Product.aspx?ty=pb&pid=33643
I am hoping to have someone come and do the work. From which i hope to learn a little.
Posted 10 November 2009 - 07:19 PM
You can get up to speed with welding quite quick - get some scrap practice metal and a basic welder and go for it!!
If you're not sure, what about asking about your local mini club? You're bound to find someone who does their own car and is more likely to do a much better job for much less money as they take more care....
Edited by robtheplod, 10 November 2009 - 07:23 PM.
Posted 10 November 2009 - 07:50 PM
Once im back i hope that i will be able to take a course at uni, and will invest in a welder.
Sadly I am the only person in my family (in the UK) who are even slightly interested in minis, mechanics and bodywork.
The last thing i want to do is have all the work on my mini done in garages where i have no involvement whatsoever.
So i would remove the old sills, patch the holes in the floor then weld on the new sills..?
Hope to get someone over to help me, show me how its all done,.
Posted 10 November 2009 - 11:07 PM
bear in mind that once you start to cut away the rust and clean up to prepare to weld ,you will most likely find a lot of very thin metal that also needs replacing ,so to save more trips to the panel suppliers ,remove the old sill and see whats behind it before you buy the panels ,you may need inner sills also !
once you have patched up behind the sill try to get some rust preventative on the inner sill ,newly welded steel will rust very quickly once it gets damp , i have some weld thro primer (hi zinc paint ) that i use to provide some protection and it wont set on fire when you weld the sill over it !
You can get a spray guy system to inject rust proofing inside box sections which i recommend as water gets into sills very easily .
maddog
