Stuborn Head
8 replies to this topic
#1 Pauly
Pauly
  • 4,213 posts
Posted 07 November 2009 - 04:50 PM
Hi guys,
Been stripping down my 1275 today and ive come to remove the head and it wont budge an inch, ive removed everything that needs to be removed (removed heads in the past) and usually with a block of wood and a lump hammer it splits from the block, but after 3 split and battered blocks of wood it wont budge. Ive sprayed wd40 down the head studs and left it overnight now to see if it will budge in the morning, but does anyone have anymore ideas?
Thanks.
Paul.
Edited by Pauly, 07 November 2009 - 04:51 PM.
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 07 November 2009 - 04:52 PM
Fit the starter motor and spin it over, never failed me in the past.
#3 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Remove the studs with a stud extractor or 2 nuts tightened together on each stud, then try again
Paul
#4 MRA
MRA
  • 7,607 posts
Posted 07 November 2009 - 05:21 PM
you may find that the centre front stud is the culprit here :D ...... therefore remove all others and turn the head, using it as a spanner would undo a nut.. :thumbsup:
#5 Pauly
Pauly
  • 4,213 posts
Posted 07 November 2009 - 05:35 PM
Ah, may be onto something there, the center stud did look a bit seized.
Im in the middle of stripping it down so the flywheels off, transfer case, timing chain etc...
Thanks for the replies guys, will give this a bash tomorrow.
Any more ideas feel free to put them up.
Paul.
#6 benno1275
benno1275
  • 391 posts
  • Local Club: bmc
Posted 07 November 2009 - 06:13 PM
i had this problem with a austin 1300 engine and i used to prybars do you want me to bring them over so you can borrow them
#7 Pauly
Pauly
  • 4,213 posts
Posted 07 November 2009 - 06:33 PM
Its ok mate I've got prybars :wub:.
Dont really like the idea of prybars running the risk of cracking the head or damaging mating faces.
Paul.
Edited by Pauly, 07 November 2009 - 06:56 PM.
#8 Pauly
Pauly
  • 4,213 posts
Posted 08 November 2009 - 04:40 PM
Sorted it :).
Thanks guys.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 November 2009 - 04:42 PM
Now that you have it off, don't be temted to open up what appears to be a tight bore for that centre front stud to pass through. It acts as the head dowel to get the alignment right, that's why it has less clearance.
