1275 Pistons
Posted 08 November 2009 - 04:37 PM
Is there any marking on 1275 pistons to say which way they go? Theres no marking saying "front" on them, but there is a "A" which seem to point to the front of the engine?
Thanks.
Paul.
Posted 08 November 2009 - 07:23 PM
Posted 08 November 2009 - 07:31 PM
Paul.
Posted 08 November 2009 - 07:45 PM
Edited by GreaseMonkey, 08 November 2009 - 07:45 PM.
Posted 08 November 2009 - 09:43 PM
If not I can scan it in for you
Posted 08 November 2009 - 11:20 PM
Posted 09 November 2009 - 09:11 AM
Thanks.
Edited by Pauly, 09 November 2009 - 09:11 AM.
Posted 09 November 2009 - 09:20 AM
Older pistons use to have a mark on the top ( an A ) to indicate the "trust" side which should be towards the rear of the block ( in transverse configuration ) basically as the crank rotates the conrod thrusts the piston up the bore, as the rotation of the mini crank is clockwise when looking front end on from no1 piston, where the radiator is, the piston is thrust up towards the rhs of the bore, ie the back
If a piston has no thrust marking then it can be fitted either way round, but it's a good idea to arrange the rings so that the gaps are not on the thrust face.
Posted 09 November 2009 - 09:24 AM
Thanks guys.
Paul.
Posted 09 November 2009 - 01:05 PM
