Winter Prep
14 replies to this topic
#1 jcatton
jcatton
  • 12 posts
Posted 10 November 2009 - 01:26 PM
Hello,
As we are all aware by now... summer is over (well, they call it summer anyway) and winter is starting to hit :thumbsup:
What are the things I need to do to keep the engine running sweetly, prevent starting issues etc etc to make sure I dont run into any trouble over the coming months? And just keep it in as good a condition as possible all round? It is used on a daily basis and am aware that a regular hose down from salt etc will be needed.
Unfortunatly the mini is kept in the drive, and not garaged. I dont have a cover for it yet, but where can I get a half decent one from for as little money as possible?
Joe
#2 zero777
zero777
  • 48 posts
  • Local Club: Strathcona County Mini Club
Posted 10 November 2009 - 02:05 PM
http://www.theminifo...howtopic=139583
#3 Big Guns
Big Guns
  • 395 posts
  • Local Club: NORTHANTS M.O.C
Posted 10 November 2009 - 02:08 PM
Covers are on Fleabay. The rest is really just common sense. A good spraying of WD40 on leads, coil etc is always a good shout!
#4 Heather&Henrietta
Heather&Henrietta
    Boobs + Batteries = Trouble!!
  • 1,126 posts
  • Local Club: JMC & BMC
Posted 10 November 2009 - 02:17 PM
Whilst we're on this topic...where's the best place to buy a weather shield from at a good price? :thumbsup:
#5 miniman retford
miniman retford
  • 3,553 posts
Posted 10 November 2009 - 02:23 PM
Whilst we're on this topic...where's the best place to buy a weather shield from at a good price? :(
Even cheaper is to cut an old rubber floor mat & cable tie it inside the grille :thumbsup: stops the wet getting in & keeps it warmer :w00t:
#6 Big Guns
Big Guns
  • 395 posts
Posted 10 November 2009 - 02:43 PM
Miniman Retford is spot on. A piece of old vinyl etc works a treat. If you want a "pukka" one try Fleabay, there are loads on in varoius colours etc.
Cheers.....Dave
#7 biggles1293
biggles1293
  • 167 posts
Posted 10 November 2009 - 02:49 PM
Hello,
Joe
I bought a good one from Sealeys.co.uk
#8 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 November 2009 - 09:23 PM
Any colour you like: -
Click Me 1
Fitting brackets: -
Click Me 2
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 10 November 2009 - 09:24 PM
No don't use WD40 unless you really have to. That stuff will cause more problems in the long run.
:thumbsup:
#10 jaydee
jaydee
  • 8,565 posts
Posted 11 November 2009 - 10:04 AM
As above, dont use WD40, there are more usefule tricks: just smear some vaseline around the edge of the dizzy cover, where it meets to dizzy, or nip a glove to fit it over the dizzy.
I dont have a wheather shield, i've just cut an alluminium sheet and fitted with some screws inside the grille (mine is custom made) just in front of dizzy and coil, no problems at all, in the pouring rain and running over puddles.
#11 djshongo
djshongo
  • 260 posts
  • Local Club: None Yet!
Posted 11 November 2009 - 01:11 PM
cable ttie mat is a great idea! :D
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 November 2009 - 01:22 PM
Don't do that either, not on the outside of the dizzy at least as that will go wrong faster than WD40 will. Fit a rubber glove if you must but the best thing to do is keep the ignition system and carb controls clean. Keep everything clean, it really does work better.
#13 jaydee
jaydee
  • 8,565 posts
Posted 11 November 2009 - 02:00 PM
Yes Dan, i meant on the inside, is the inside of the edge of the dizzy cap that slides over the body, and the vaseline provides a better seal to avoid umidity getting through and melting on the inside. Anything like grease, oil and vaseline will only trap dirt if applyed on the outside.
#14 Big Guns
Big Guns
  • 395 posts
Posted 11 November 2009 - 02:26 PM
I still swear by WD40. I've used for years on Stags, Spitfires, Cortinas etc, etc. Never had a problem with it. Save the vas for something else!!!
#15 djshongo
djshongo
  • 260 posts
Posted 11 November 2009 - 02:54 PM
WD40 fixes everything... apart from my electrics !
Edited by djshongo, 11 November 2009 - 02:56 PM.
