Roof Lining....the Mdf Way?
Posted 11 November 2009 - 02:59 PM
Posted 11 November 2009 - 03:31 PM
Posted 11 November 2009 - 03:37 PM
Posted 11 November 2009 - 03:41 PM
But good luck if you decide to go with it, and if it works post some pics!!
Posted 11 November 2009 - 06:39 PM
Posted 11 November 2009 - 06:40 PM
ask miniboo for a picture of his
Posted 11 November 2009 - 06:42 PM
Posted 11 November 2009 - 06:48 PM
Posted 11 November 2009 - 09:09 PM
Posted 11 November 2009 - 09:10 PM
Posted 11 November 2009 - 09:18 PM
Posted 11 November 2009 - 09:19 PM
Posted 11 November 2009 - 09:42 PM
Posted 12 November 2009 - 08:37 AM
MDF works fine but you will have to use 3mm and do 2 layers as 6mm isn't flexible enough to bend at the ends. If you look at my project thread it shows how I have done mine.
The only problem with doing it in MDF is having the car off the road while the glue dries and the wood takes shape. I used spray contact adhesive between the roof and 1st layer and a combination of spray glue and strong PVA between the layers.
Hope this helps and good luck;)
Posted 12 November 2009 - 08:50 AM
Cheers.....Dave
