I don't think such tower bolts exist?
The long hex rod was originally designed for pre-1976 Minis, which had twin tower bolts each side and a hole in the centre. Basically for the pre-1976 non rubber mounted front subframes.
For the rear, I believe owners used to cut out holes in the rear panel so the hex rod could be inserted?
That does make sense, as the car is a 1974 and has had holes cut out in the rear panel! looks like some one has changed the subframe then, dont you need to stregnthen up the section which accepts the large single bolt? when you change from an early to late type subframe??
So it's either change to the normal set of Hi-Lo's (nut and bolt job) or convert it back to older style subframe.!
Out of the two types of front subframes fitted to mini's is one of them considered better then the other?? (say for competition use)
Many thanks
Kevin
Being a 1974 model means it's a MK3 and it should have the solid mounted subframe. So a later type subframe has obviously been fitted, but I'd have thought the bulkhead would need modifying as a result?
As for the best type of subframe, well I personally prefer the pre-1976 solid mounted subframe, because the handling is far better as there's no rubber mounts to upset things.
You can solid mount a post-1976 subframe with steel or polyurethane mounts though. But many claim you get more noise or vibration than you would on an original pre-1976 type?
Edited by taffy1967, 12 November 2009 - 02:42 PM.
