Vauxhall Crankshaft Failure
Posted 16 November 2009 - 07:11 PM
Took the car to local vauxhall at 3:50 am and they looked at it at 12noon ish today and the crankshaft has broken on the exhaust cycle taking the cambelt and timingchain with it ..
my question is has anyone else experienced this ...
but on the plus the mini is now taking me to uni all of this week ! hah
thanks Bamby
Posted 16 November 2009 - 07:31 PM
I also can't quite see how the crankshaft breaking on the exhaust cycle would make any difference - as there is always a cylinder on the exhaust cycle - if you see what im getting at.
I have seen a late style corsa break an exhaust cam, and it was fully repairable althought the cam was about £280 from vauxhall. But we didn't need th change anything else bar the cam - it just ran like a tractor on 2/3 cylinders.
IF the crank has broken then that is a serious failure and the engine is scrap - i feel you might not have been told the full problem.
Does the car still run, or was running before you pulled over - was it like i mentioned above - i.e. running and just about pulling itself along and making a clicking noise every now and again??
The exhaust light - do you mean engine light? If so that is the engine management light and would suggest anything from a sensor not picking up (from broken cam) to dodgy emissions.
Posted 16 November 2009 - 07:34 PM
Posted 16 November 2009 - 07:41 PM
What engine is in your corsa nick?? As if it is a 1.2 16v lump as in the mk3 corsa's then it doesn't have a cam belt so it sounds like they are over quoting.
its a 55 plate corsa c (2005) the light that came on was the one that indicated the exhaust emmissions. it was firing on two (like a tractor) and a loud clunking sound so was the dicision by aa man was not to turn it on again and leave it to Vauxhall.
the crank isnt broken as thats a replacement engine job. this xplains it better than i can but ours is virtually the same Vauxcam
Posted 17 November 2009 - 10:55 AM
You should be able to just replace the cam, it isn't cheap as I have already said but as for vauxhall quoting for a new cambelt - that is a pure lie as the new corsa's are run on chains.
Plus we replaced only the cam so they shouldn't have to replace the timing chain etc.
As i said i think Vauxhall are just trying to over-quote for work that doesn't really need to be done.
Posted 17 November 2009 - 11:09 AM
Posted 17 November 2009 - 11:33 AM
Fitting a camshaft is much less work than fitting a head, as all you have to do is hold the timing chain sprocket while you swap the broken cam for the new one
It is a shame you are no closer Nick as I could have done it for you.
Posted 17 November 2009 - 11:36 AM
It sounds like the camshaft also to me i would get a full head and cam from a breakers yard and a new head gasket then get someone to fit it on the drive i do not think your crank has snapped that would be rare the garages are to dear with new parts labour etc...
The engine nick has is a twin-cam chain driven version - and would involve stripping the side of the engine to remove the timing chain (poxy job) and them timing it all back up again. Plus the additional costs of gaskets etc (the engine side gasket is about £50 on it's own).
See if you can find a proper old school mechanic Nick - not a "fitter" as most are nowadays.
Posted 17 November 2009 - 01:01 PM
Posted 17 November 2009 - 07:24 PM
to be honnest its not the cost of the parts thats costing us its the labour at 66.76an hour+ VAt
Posted 17 November 2009 - 08:10 PM
Posted 17 November 2009 - 11:09 PM
Shop around and find a small garage / mechanic that trades on its reputation - as they will want to do a good joba nd have you recommend them.
Put it this way my uncle charged £100 labour (works on roughly £30/£35 per hour), plus the cost of a cam to sort the corsa out that we had. No extras, no hidden parts that need replacing etc.
It seems this is a common failure - which is more worrying.
Hope you get it sorted Nick, but id be looking at a bill of £400 - £500 + VAT bearing in mind the cam will be around £300 from Vauxhall.
Posted 20 November 2009 - 04:12 PM
needless to say it drives like it did 3 years ago when we got it
total bill was £921.86 so still not cheap but the cars back and working
Posted 20 November 2009 - 04:44 PM
well got the car back from vauxhall last nite aT 6PM after they did a ful road test ...
needless to say it drives like it did 3 years ago when we got it![]()
Hell's teeth Nick, your right that ain't cheap, Ouch!
Posted 20 November 2009 - 05:55 PM
Its the cam shaft that has gone !!
so here is a quick blast of the bill :
vauxhall labour charge £504.56
camshaft £236.90
timing chain £39.10
slide rail £2.39
gasket £12.82
gasket £18.80
gasket £23.52
screw-torx £0.87
seal ring £15.30
chain tensioner £34.04
guide rail £3.34
rail £5.53
seal £1.20
antifreeze £7.02
10w/40w oil £16.50
bulb £7.25
total .... £929.14
