Long Stroke Engine Swap
#61
Posted 21 February 2010 - 06:44 PM
#62
Posted 23 February 2010 - 08:51 PM
hi there, im looking to do the same thing making m own mastercylinder set up, what car are those master cylinders of tho?I needed to try out my subframe to make sure it fitted...sure does! And I don't have to mod the inner wings either!
(the original sides of the subframe are only in place to jig up the engine mount holes, once i've done this I will cut them out and replace with the new engine mountings).
And my twin master cylinder conversion box. I really wanted the KAD one, but couldn't justify spending best part of £200 on one...so I made my own! (the KAD one doesn't have lightening holes in it either)
cheers
#63
Posted 24 February 2010 - 08:38 PM
They're not off any particular car. They're just wilwood master cylinders.
Cheers!
#64
Posted 24 February 2010 - 11:40 PM
Oh my
#65
Posted 07 March 2010 - 08:39 PM
Oh my
Cheers dude!
Bit of a 1 step forward, 2 steps back
My daily blew up on Friday so i've had to put the 1000 back in the mini to get me around
#66
Posted 07 March 2010 - 09:06 PM
love the build dude, and i proper love that exhaust, any tips on how to get/make one :L
#67
Posted 11 March 2010 - 07:11 PM
what a beaut!
Cheers chap! Best thing to do with the bike cans is to get one, then make the flanges etc to suit. A lot of cans vary, some are slip on, some bolt on...you can pick up damaged cans pretty cheapo mind!
#68
Posted 11 March 2010 - 07:28 PM
#69
Posted 11 March 2010 - 08:23 PM
You'll be able to see where to put it if you trial fit the weber without the ram pipes, you just have to fit the box centre with the carb. I've just fitted mine.Loving the project dude...dont spose i could ask a masive favour, do you know how far over you've wleded the battery box in your bulkhead to get clearance for the weber?
Edited by george91, 11 March 2010 - 08:24 PM.
#70
Posted 11 March 2010 - 08:38 PM
Cheers bud! As George said above, if you've got the engine in place you can generally tell where it wants to go. I can get the tape out for you, but it might not be great as my engine isn't straight in the frame (school boy on my behalf
On a different note, she's driving again and i've made a few observations...
- 998's are still really slow
- Solid mounted frames and coilovers bang like hell on pot holes LOL
- A verto clutch will work with a pre-verto arm and slave
Can't wait for this 1430!
#71
Posted 11 March 2010 - 09:22 PM
#72
Posted 12 March 2010 - 01:59 PM
That engine will be a monster, but I reackon you'll soon get bored with it and want more, everyone does.
Ben
#73
Posted 18 March 2010 - 08:05 PM
Ugh don't say that
Whilst we're on the subject...now i've got all the bits I can write up a spec for the engine! (plus i'm a bit bored)
1430cc
Block offset bored to 73.5
Kent 286 camshaft
Omega pistons
'S' rods (balanced)
MED 84mm stroke crank, backdrilled, wedged
ACL bearings
MED dynamic 'S' damper
Slightly lightened flywheel
Orange diaphragm
Turbo clutch plate
Standard back plate
Complete rotating assembley balanced
Oil galleries tapped out for grub screws
Spur drop gears 1:1
A+ gearbox
Central oil pick up
Minispares X pin diff
3.1 FD
Janspeed racing head
skimmed for 12:1 C/R on V power
Head dowelled on block
1.5:1 roller tip rockers, spacers replaced with springs
Evacusump breather system
Weber 45
ITG foam filter
Maniflow 7" inlet manifold
Maniflow stage 2 LCB
Front mount rad
Aldon yellow dizzy
Not a clue on potential output, but I'd be happy with 100 ponies!
#74
Posted 19 March 2010 - 08:27 PM
#75
Posted 19 March 2010 - 08:59 PM
Tasty spec mate....geussing it'll be all about the torque though with a long stroke crank!
Well with a 286 cam and 1.5 ratio rockers, it's going to be an absolute screamer!
