Hi, I got my engine block bored out to 1061cc a couple months ago from a engine machinest along with various other things done to the block, I also got them to press the new +0.80 pistons onto the A+ floating rods (Mini spares flat top mega type). I started to put the new pistons into the block fitted with the rings, the correct way with the arrow pointing to the water pump and them facing the correct way as it says on the pistons. The piston went into the bore fine, i then fitted the ARP bolts and torqued them up. After finishing one completely i spun the engine over by hand but when i spun it the rod hitted the side of the block, At first i thought it was the wrong rod bolts so i changed them to the standard ones, but the rod still hits the side. So i looked at the piston again to make sure i put it in the way it says. (it was) By this time i was somewhat confused!! I had a closer look at all 4 of the pistons to see that there all the same with the arrow facing the water pump and facing front etc.... two of the four pistons have been fitted the wrong way! with them facing 180degrees the other way.
No. 1&4 have been fitted the wrong way, and so when you fit them as they should they hit the side of the block because of the offset of the rod. I rang them up and they said ''we havent seen mini pistons with arrows''. They also said to me ''they should be okay to fit because they are not offset pistons'' ??
My question is will they be okay to fit with two of them being the wrong way round or will i need to get them pressed off and put the correct way?
(when i say will they be okay i dont mean just put them both in as i have already and smashes the block lol. obiously i would turn the complete piston/conrod around) so two of the arrows would be facing the wrong way so they fit as they should.
I have probley made this look really confusing, hopefully i havent, thanks.
Edited by Racer_Pete, 17 November 2009 - 10:41 PM.
