Parts Cleaner
17 replies to this topic
#1 Pauly
Pauly
  • 4,213 posts
Posted 18 November 2009 - 09:24 AM
Hi all,
Anyone know to a good parts cleaner thats better than gunk?
Thanks.
Paul.
#2 cobblers
cobblers
  • 181 posts
Posted 18 November 2009 - 09:30 AM
Gunk works well but takes time to get through thick stuff, and still leaves a slight greasy film. If you scrape the worst of any real buildup away first with an old butter knife, it loosens the rest and it comes off nice and easy from my experience, but the stink of it gets in your skin and clothes for ages.
I bought a 5 litre tub of brake cleaner for about £12 (Here)
and it worked great, got the muck off then evaporated and didn't stink the place out for weeks. Cleaned my whole engine externally and all internal components for the rebuild back to spotless with 5L of it, and I've still got about 1l left. Absolutely great stuff.
It's also brilliant for cleaning the acres of gasket surface up on mini engines, it gets old instant gasket and solid paper gaskets off, giving you a proper grease free surface for the new gasket sealant to get a good grab on.
Edited by cobblers, 18 November 2009 - 09:33 AM.
#3 miniman_7
miniman_7
  • 286 posts
  • Local Club: Looking...
Posted 18 November 2009 - 09:42 AM
I've used cilit bang to clean an engine before. Worked a treat!
Bang and the dirt is gone!
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 November 2009 - 10:17 AM
Depends what level of 'clean' you want...
Find a local engineering company, for general parts cleaning, I use a product called Slick HD, goes in your std machine mart type parts washer, good stuff and lasts for ages..
Data sheet for Slick HD - http://fleming-tech....23/083251SL.HTM
However, if you want "Really" clean then you need some serious *melon*... the stuff I use in my dip tank is a decarbonising solution, needs to be carefully managed, and is very expensive...
Look up DICHLOROMETHANE on google...
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 November 2009 - 10:22 AM
There is a new Gunk product, called Gunk Ultra or Gunk Plus or something that works really really well. It's in a spray bottle, leave it on for 2 minutes and wipe with a wet cloth and you get right through the grease in one go.
#6 01smartc
01smartc
  • 1,412 posts
Posted 18 November 2009 - 10:31 AM
Kerosene works quite well
#7 Pauly
Pauly
  • 4,213 posts
Posted 18 November 2009 - 10:36 AM
Its to clean out my gearbox casing.
I used diesel before but you stink of it afterwards.
Theres a car cleaning place by me that sell solvent cleaner, suppose its like gunk?
http://www.carchem.c...aser-p-204.html
Paul.
#8 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 18 November 2009 - 11:06 AM
Hi all,
Thanks.
Paul.
I filed my parts wash with Kerosene, I tried gunk & some water based degreasers but when it comes to getting thick grease & oil off they were rubbish. Kerosene is spot on, cleans it up lovelly, But don't get any sparks etc near it or you could have some fun. :D
#9 Alex Kay
Alex Kay
  • 22 posts
Posted 18 November 2009 - 11:37 AM
Hi all,
Thanks.
Paul.
I agree,, I too have tried water based degreasers and I was not impressed. I found them effective if you could leave the parts soak for a day,, then the grime fell off,,, but if you just want to scrub it clean quickly and effectively, I reckon its hard to go past Kero.
A trick I use when I know that I'm going to pull down a motor and gear box for a rebuild, is that I run Diesel Engine Oil in it for 50km. It has a higher level of detergents than normal oil, so when you pull it down it is much cleaner to start with. Some people aren't big on the idea though for the reason than they worry that it runs too clean and can maybe cause damage as a reslut,, but my argument is that if its only for 50km you won't do any damage and if you're going to rebuild it what does it matter anyway?
Good luck with your search
#10 jaydee
jaydee
  • 8,565 posts
Posted 18 November 2009 - 11:44 AM
Paul.
Try cillit bang .. :D
Edited by jaydee, 18 November 2009 - 12:14 PM.
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 November 2009 - 11:55 AM
DON'T USE OVEN CLEANER ON ALUMINIUM....
If you read the label on the side you will find out why... It contains a chemical ( can't remeber what it is off the top of my head ) which attacks aluminium, like wise with commercial dishwasher solutions, you need to find one which is specifically for aluminium therefore at least twice the price..
I'll find out what the chemical is, and it's alternative...
It came to me in a flash of inspiration...
Sodium hydroxide - BAD
Potassium hydroxide - GOOD
Edited by GuessWorks.co.uk, 18 November 2009 - 12:00 PM.
#12 Pooky
Pooky
  • 5,691 posts
Posted 18 November 2009 - 12:05 PM
I've been using Jizer for a while and think it's alright. Even diluted in a spray bottle gets clean most parts
#13 jaydee
jaydee
  • 8,565 posts
Posted 18 November 2009 - 12:16 PM
Yeah..forgot about that!
#14 01smartc
01smartc
  • 1,412 posts
Posted 18 November 2009 - 12:36 PM
You can just pop it down and i will run it through the chemical hotwash... you cant get better than that, the heat and the cleaner works a treat
Chris @ Smart Performance
#15 Pauly
Pauly
  • 4,213 posts
Posted 18 November 2009 - 04:47 PM
Sorted it now, got a big 'ol can of JIZER! :D. Think its better than gunk, cleans the casing up nicely.
Paul.
