fuel mixture
5 replies to this topic
#1 minimole
minimole
  • 781 posts
Posted 14 October 2005 - 07:44 AM
is there anyway to tell how learn or rich your fuel is because i am putting my hiff44 carb on the new engine and i am woried that it will be running to learn it use to run a little rich onthe 1275 engine it was on. i cant getit to a rolling for a little while. thanks in advance.
#2 vasi
vasi
  • 897 posts
  • Local Club: Minis 'n' Oatcakes
Posted 14 October 2005 - 08:11 AM
A gunsons colortune is a useful tool and gives you an immediate visual indication as to the composition of fuel / air.
Ideally you need to hit the rollers as soon as possible though.
#3 minimole
minimole
  • 781 posts
Posted 14 October 2005 - 08:23 AM
thanks for the info. but where might ifind this colour tune?
#4 Will
Will
  • 1,223 posts
Posted 14 October 2005 - 08:29 AM
ebay?
google it.
#5 Will
Will
  • 1,223 posts
Posted 14 October 2005 - 08:30 AM
ahaaaaa
Clicky
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 October 2005 - 09:41 AM
To set an HIF to an initial starting setting, wind the mixture screw in until the top of the jet is flush with the venturi, and then two turns clockwise... that'll get the car going and will not be too far off the mark assuming the needle is the right one.
The drive down to Halfrauds who will probably have on in stock...
