Drip Drop
8 replies to this topic
#1 trafficface09
trafficface09
  • 757 posts
  • Local Club: not yet but soon
Posted 20 November 2009 - 07:41 PM
My floor keeps filling up with water and i am aware there are a few holes but is there a good trick that can be used to find the holes.
i have seen some water coming from the rubbers on the front windscreen even though the rubber looks fine, would i need to replace them?
there are also some holes in the floor but i fail to see how water can travel up into the car.
when i get on with welding the last thing i want to do is miss any holes.
#2 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 20 November 2009 - 07:45 PM
there will always be some holes in the floor for drainage so make sure they stay, unless ofcourse they are very rusty and HUGE :)
get some vaseline and stick it on the seal where you think its leaking then wait for it to rain and if theres not water
then problem solved
#3 secondopsman
secondopsman
  • 661 posts
Posted 20 November 2009 - 07:53 PM
Im sure someone mentioned on here that a good way to find were water is coming in is to dust the area with talc then when it leaks you can see were from easliy.
Pete
#4 jt89
jt89
  • 162 posts
  • Local Club: Nope
Posted 20 November 2009 - 08:03 PM
If your rubber looks fine you don't need to replace it-just re-seal it.Take the insert out of the rubber, using a skeleton gun run a bead of black arbomast in between the rubber and glass all the way round, and if you want in between the rubber and body just to be sure. Re-insert the filler strip/insert.And clean away excess arbomast. We use it all the time it works a treat (i fit windscreens lol) http://cgi.ebay.co.u...e#ht_1993wt_958
#5 suvla
suvla
  • 46 posts
Posted 20 November 2009 - 08:24 PM
to check on the roof and upper area get a watering can and remove roof lining etc and it is painfully boring searching but it has to be done and you will find it if your persistant or strip completly and take through a auto car was thats another good way of spotting them
#6 gonzoavfc
gonzoavfc
  • 271 posts
Posted 20 November 2009 - 09:39 PM
check the holes in the bulkhead where the pedals go and the blank one of the passenger side, in the top of them is a ablanking plate on passenger side, and this always leaks, and the clutch cylinder and a plate on the
#7 trafficface09
trafficface09
  • 757 posts
Posted 22 November 2009 - 08:20 PM
Thank you all. very good tips i will try them all out.
Hopefully no more drip drop ha ha
#8 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 22 November 2009 - 10:04 PM
similar problem, i keep getting water in my rear seat pan and as the seat bottom is really just a sponge its none to comfortable for the passengers!! i put new door and rear quarter window seals in bout 6 months ago so it couldnt be them, rear window seal???
#9 ste88
ste88
  • 258 posts
  • Local Club: LCMOC
Posted 24 November 2009 - 11:44 PM
i found a lot of water in the rear seat, the bench part, i think its my rear window as the wooden shelf at the back is soaked, think its dripping throught to the boot aswell :shifty:
