1380 Engine
3 replies to this topic
#1 TheKing777
TheKing777
  • 153 posts
Posted 21 November 2009 - 05:48 PM
1380 Engine, standard 1275 gearbox, standard head. Only done 200 miles since crank, headgasket and gearbox gasket changed. Has an uprated cam (276 or 286).Have dyno printout at 85 bhp (I'll confirm this)
No smoke, no leaks.
How much you think this would be worth.
#2 davidv
davidv
    Flowers of JOY.
  • 416 posts
Posted 21 November 2009 - 06:30 PM
1380s are worth a fair bit someone else would do the head most like to see them running but no problem on yours you have the papers and tell them a small refund if not happy that engine could go up a lot on power with more work if its mint you must be starting of at about £500
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 23 November 2009 - 11:59 AM
why was the crank replaced ?
When was it built / by whom ( prior to the crank being replaced )
How many miles ( owners ) since it was built.
#4 TheKing777
TheKing777
  • 153 posts
Posted 23 November 2009 - 12:15 PM
When I bought it the flywheel had been spun off thecrank so I replaced it with a Minisport Nitrocarbonised Crank.
The engine had been taken out of a metro with 45k on the clock then left in a garage for a year whilst the guy before me changed the cam. He never got round to using it. I bought it on a whim but it turned out ok.
