Think I've got my head around compression ratios, but my maths skills are shocking so I need someone to double check for me?
Theres 2 ways I may be having the block machined. 1 is standard bore & pistons (which have 8cc dish, 21962 piston) and another is re-bore +20 = 1293 with ae 21251 pistons which have a 8.4cc dish.
So calculations for option one, at the moment the comp ratio is 9.4:1 (standard HLE)
All calcs are done according to vizard.
To get 10.25:1 comp ratio.
10.25 - 1 = 9.25
1275/4 = 318.75
318.75/9.25 = 34.4 (total chamber volume required)
Add ringland (0.7cc) piston dish (8cc) piston to deck height (37 thou = 3.7cc) and gasket thickness (4cc)
0.7+8+3.7+4 = 16.4 (which is what the other things above add up to)
So...
34.4-16.4 = 18cc (and the size the head combustion chamber volume needs to be for 10.25:1)??
Option 2
10.25:1 comp ratio
10.25 - = 9.25
1293/4 = 323.25
323.25 - 9.25 = 34.9 (total vol)
0.7+8.4 (dish for 21251's)+3.7+4 = 16.8
so...
34.9 - 16.8 = 18.1 (new head chamber vol)???
Now if I wanted to skim so much off the block deck (say 10 thou) would I subtract 10 from 37 (current piston to deck height?) giving me 2.7cc?
Thanks guys.
Paul.
Edited by Pauly, 24 November 2009 - 06:06 PM.
