Stromberg Carb Info Please
8 replies to this topic
#1 Myles Dyson
Myles Dyson
    Just On Tickover
  • 6 posts
Posted 26 November 2009 - 02:37 PM
1275:
198?:
mini is runnin on a 1275 gt engine & I am after some info on the stromberg carb, it seems to be running a little weak and am unsure of what jet 2 adjust, im not sure of the exact model of the carb, if u know the model or
If you know of any carb diagrams online that would be a great help..
Thank you :D
B
#2 jaydee
jaydee
  • 8,565 posts
Posted 26 November 2009 - 02:44 PM
www.burlen.co.uk :D
If yours a proper 1275 gt engine, your carb should be an HS4. Get hold of a SU service manual i fyou can, its a very good handbook.
#3 Myles Dyson
Myles Dyson
    Just On Tickover
  • 6 posts
Posted 26 November 2009 - 02:51 PM
ah right ok.. it could well be a HSU im new to this game.. will check out the link cheers Jaydee :D
#4 jaydee
jaydee
  • 8,565 posts
Posted 26 November 2009 - 02:56 PM
Yeah, stromberg carbs just look similar, and honestly i've never seen one fitted to a mini, maybe to some MGs, but not on a mini.
#5 oli8925
oli8925
  • 2,260 posts
Posted 26 November 2009 - 03:00 PM
post a picture up. strommies do look similar but they look more squashed than HS carbs. if it is a stromberg, get an HS4. strombergs really are no where near as good as HS in my opinion. got one on my viva and was considering going to HS carbs, but decided on weber instead :D
#6 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 26 November 2009 - 03:16 PM
interesting actually iv'e seen twin Stromberg carbs on a mini engine, only the once though!
#7 oli8925
oli8925
  • 2,260 posts
Posted 26 November 2009 - 03:59 PM
really dont see the point. as i said SU's are much better IMO. though i guess its something different on a mini.
#8 Myles Dyson
Myles Dyson
    Just On Tickover
  • 6 posts
Posted 27 November 2009 - 07:31 PM
after Jaydee said it should be a HS4 i went under the hood to have a propper look.. and it DEFFO isnt a SU..
The problem i am having is that it is there is a slight miss/hesitation when i put my foot to the floor through 1st 2nd & 3rd, but when i fully apply the manual choke it runs perfect through the gears (hence the fact i thought it was running a little weak).. i am doing a auto test on sunday, and am hoping to get it sorted by then..
Failing that i am bidding for an SU on ebay.. so fingers crossed i win the bid :proud:
B :)
Edited by Myles Dyson, 27 November 2009 - 07:34 PM.
#9 1.3Cooper
1.3Cooper
  • 39 posts
Posted 27 November 2009 - 10:10 PM
if it is a stromberg - easy things to check are that there is enough damper oil in the top same as a SU and also take the top off - just a few screws- and make sure the diaphram has not split
