Removing Lower Dash Facia
11 replies to this topic
#1 ODD1991
ODD1991
  • 149 posts
Posted 26 November 2009 - 06:11 PM
hi, i want to recover my upper dash and lower facia with black vinyl.
i have removed the top facia but cannot figure out how to remove the bottom one.
could anyone tell my how to remove it so i can recover it?
thanks in advance
#2 nile-jackson
nile-jackson
  • 155 posts
Posted 26 November 2009 - 06:33 PM
i want the same done, does anyone know of a company that offer the service inc fitting?
#3 hayno
hayno
  • 98 posts
Posted 26 November 2009 - 06:46 PM
You could have a go yourself, me and a mate just recovered the top dash rail at the weekend i did mine in black leatherette and he did in red! Looks pretty good. managed to do each one in an hour including removing and refitting it, and the material cost us a mere fiver and still got enough to do the bottom this weekend! :geek: Aint had a look about how it comes off yet!
#4 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 26 November 2009 - 06:47 PM
to remove the bottom dash rail you need to pull the chrome trim off at the back (on the top) thai is if it is fitted.
then youll need to undo the screws that hold the heater up.
behind the switches are 2 little brackets that have nuts on holding it to the metal, remove these.
the padded dash rail is usually glued in place so it may take some pulling.
then just take the switch pannel off.
re-cover and re-fit
#5 hayno
hayno
  • 98 posts
Posted 26 November 2009 - 06:49 PM
re-cover and re-fit
Cheers for that ill take the leaves out out me heater at the same time :geek:
#6 ODD1991
ODD1991
  • 149 posts
Posted 26 November 2009 - 07:07 PM
re-cover and re-fit
haha, i will have to check my heater. thanks a lot for the instructions
#7 joecowan
joecowan
  • 128 posts
Posted 27 November 2009 - 11:55 PM
i gona do this to my dash rail in coulpe of weeks. there is is a company that will do it for you called retro retrims. they will send u pre cut vynle covering with fitting instructions or they will do it for you.
RETRO RETRIMS LINK
#8 ODD1991
ODD1991
  • 149 posts
Posted 28 November 2009 - 12:50 AM
RETRO RETRIMS LINK
hi, thanks for that but i think i will have a go on my own 1st.
thanks again
#9 Bedsref
Bedsref
  • 58 posts
Posted 28 November 2009 - 09:01 AM
out of curiosity - where are Retro Retrims based?
#10 gonzoavfc
gonzoavfc
  • 271 posts
Posted 28 November 2009 - 10:11 AM
in the west bromwich area.
#11 nile-jackson
nile-jackson
  • 155 posts
Posted 28 November 2009 - 09:58 PM
for a total dummy, how does the top dash rail come off?
I am going to attempt to refit the dash, and re-trim both top and bottom dash rails, would anyone be able to shed some light on how to get them all out?
If i get the top off then i should be able to get the actual dash off, then find it easy enough to get the bottom one off right?
#12 tadleysimon
tadleysimon
  • 1,458 posts
Posted 28 November 2009 - 10:27 PM
the dashboard comes out before the dashrails. but the top rail is help in with 3 bolts. a bit of a pint with the windscreen in but its possible
