hi,
So time for a another update...
Once I got the engine out I spent a bit of time cleaning up the engine bay, undersealing the passenger side floorpan, stripping down the old engine to move it about of the way and generally tidying up, all very boring jobs but they needed to be done!
Once I'd done that I got my mate adam to come round and help me lift the engine in. I was particularly nervous about this bit!! As the head is of a different design I had to think of a new way to lift it into the engine bay, in the end we used a tow rope and a ratchet strap as back up! after alot of swearing and wiggling we ended up with this:
I was just relieved to get in without dropping it to be honest and we left it at that for the night.
The next day I went out and fitted the exhaust manifold, which meant taking out the pot joint to get enough room for the big bore pipes, but atleast now its on!
Once we had that done it was just a case of painting up the hubs and cleaning the driveshafts up, as I wanted to get it back on four wheels so I could move it about. Didn't go too bad and the only problems were waiting for the paint to dry and two top baljoints needing renewing before it goes back on the road.
A few pictures of how it looks back on its wheels:
As you can see from the pictures I've now fitted the starter motor (not wired up yet as I've gotta convert it), the throttle bodies, the coil pack and a few other bits and bobs.
Today I started messing about with the radiator and cooling system. Before I started building the car a decided on a nice shiny alloy rad. And so far its being a complete pain in the backside! I've had to cut a bit of the car off to get it in and the bracket I had to replace the top rad bracket (the one that bolts to the head as standard) doesn't fit over the new rad as its bigger, so I'm gonna have to make a new one of those now!
However it does look great!
A few more pictures that I've taken...
Shiny throttle bodies and ram pipes
Cambelt and bottom hose
Trigger wheel and rad clearance
Thanks for looking,
Ian
Edited by ianjobber87, 29 December 2009 - 04:07 PM.
