Hydro Gas/ Cone Suspension
5 replies to this topic
#1 skippy123
skippy123
  • 40 posts
Posted 28 November 2009 - 01:37 PM
Hi guys,
was wondering if I can replace the hydro gas suspension with rubber cone's?
are the sub frame mount different for the rubber cone suspension is it a strait swap??
thanks
#2 MRA
MRA
  • 7,607 posts
Posted 28 November 2009 - 02:39 PM
The subframes are different.
#3 skippy123
skippy123
  • 40 posts
Posted 29 November 2009 - 12:10 AM
how different? could i modify mine or do i need a hole new different sub frame?
#4 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 29 November 2009 - 03:25 AM
Here is a conversion kit from MiniMania. Not cheap.
http://www.minimania...0/InvDetail.cfm
Hope that helps,
Ivan
#5 skippy123
skippy123
  • 40 posts
Posted 29 November 2009 - 05:34 AM
so the actual rubber cones is a direct swap from the hydro bags?
do i need to have shock absorbers along side the rubber cones or will it work without??
thanks
#6 Cooperman
  • 23,294 posts
Posted 29 November 2009 - 02:50 PM
The hydro sub-frames have small lugs to which the hydro units fit. You just knock those in or grind them off and the rubber springs will fit fin.
The top arms are a different ratio, but thay don't really need changing, although Hi-lo's will help to get the ride height correct.
At the rear you do the same with the little lugs, then fit the rubber springs and trumpets. The only other difference is the way the handbrake cable is run, but is not an issue.
A mod well worth doing IMHO.
