Wet Floor In Driver Foot Well
14 replies to this topic
#1 mdickson
mdickson
  • 217 posts
  • Local Club: SMAC
Posted 28 November 2009 - 09:36 PM
Cooper 1275 Mpi
1996
Jumped in to the car this morning to move it to give it a big wash and the mat was soaking as was the carpet.
So I started thinking what it could be checked the headling and all the high spots expecting to find the cause, but everything was dry.
Had a feel in the passenger side and it is all dry.
The rear of the drivers side is also dry.
So I was a bit stumped. The one difference is that my drive has a slight incline and last night for the first time I reversed onto the drive.
This meant that the car was front higher than the rear. Not sure if this may have an effect.
The drivers side door step has a small hole which is gradually getting bigger.
So I got it up on the ramps and axle stands and had a look underneath but nothing jumped up to say this is the route cause of the problem.
So I was wondering if there are any usual problems on minis which may result in this type of a problem.
All advice is greatly appreciated.
Martin.
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 28 November 2009 - 10:34 PM
The front windscreen seal might be the culprit.
More so if your scuttle is quietly rusting away underneath it (quite common I'm afraid).
#3 p.park
p.park
  • 217 posts
Posted 28 November 2009 - 11:21 PM
i'm putting my money on the driver's side door seal
i've had a similar issue
Edited by p.park, 28 November 2009 - 11:24 PM.
#4 biggles1293
biggles1293
  • 167 posts
Posted 29 November 2009 - 07:11 PM
Theres loads on the forum about leaks, most common areas are air vents behind dash, manufactured holes in bulkhead by pedal box and same on the passenger side, or doors, oh and generally rusty floors with holes in, oh and maybe windscreen seals gone, basically do a search on here, plenty of options to choose from, process of elimination really, but if you have carpets in, get them out to dry, soggy carpets= condensation build up and trapped moisture on the floor pans which we all know Mr Rust loves!
#5 benb12
benb12
  • 1,483 posts
Posted 29 November 2009 - 07:19 PM
Could also be the heater leaking!
#6 mini-ferns
mini-ferns
    Just On Tickover
  • 7 posts
Posted 29 November 2009 - 08:17 PM
I had the same problem on both sides, i replaced the windscreen seal and that seemed to do the job.
No more puddles in the footwells rusting holes in the floor. :)
#7 Robbie
Robbie
  • 517 posts
  • Local Club: Renegade Mini Fun Club!
Posted 29 November 2009 - 08:22 PM
If it's the first time you parked it with the front higher than the back, and it's the first time it's leaked, then it looks like the windscreen seal is the prime suspect.
#8 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 29 November 2009 - 08:23 PM
When it rains/wash the car water runs down the window, into the door and over the seal, into the drivers footwell in mine.
I still havent got round to changing the seals...Il put it on the to do list :)
#9 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 29 November 2009 - 08:25 PM
Also the rain will be running back along the channels the bonnet lip sits in and may be finding its way through a hole in the bulkhead.
Edited by Teapot, 29 November 2009 - 08:26 PM.
#10 TooFPaste39
TooFPaste39
  • 83 posts
Posted 29 November 2009 - 10:12 PM
Im very new to Mini's but I have one question. Why did they put holes in the floor? Im currently wondering why I have two holes in the floor pan w/ rubber grommets. It doesnt make any sense to me. Even w/ the rubber grommets in, water still gets in. I checked my heater and around the bulk head, no sign of moisture so it is def. coming from those holes. Why did they put holes there?
#11 mdickson
mdickson
  • 217 posts
  • Local Club: SMAC
Posted 29 November 2009 - 10:32 PM
Thanks guys I think I need to check out my windscreen seal and see if it could be the cause.
TooFPaste39 I am not sure about Mini's but I know in more modern cars the holes can be for a number of various things from locating the panels during the assembly and manufacturing process and also to enable some drainage during the cleaning and electroplating of the body.
Martin.
#12 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 30 November 2009 - 12:32 AM
That shouldn't happen on an MPi Mini as it will have the thicker bonnet seal that runs part way down the wings.
#13 TooFPaste39
TooFPaste39
  • 83 posts
Posted 30 November 2009 - 07:20 AM
Martin.
So if I decided to weld it shut, it would do no harm?
#14 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 30 November 2009 - 07:40 AM
Sorry, Taffy, I'm not up to speed with these modern cars :kiss:
#15 gonzoavfc
gonzoavfc
  • 271 posts
Posted 30 November 2009 - 09:16 AM
during the manufacturing process teh mini was submersed in an anti roof 'bath' (hard to believe i know :kiss:) the holes in the footwell was too let the liquid draing out. i know taffy has some links to videos that show the manufacturing process that shows this.
