Ignition Coil Earth?
7 replies to this topic
#1 Charliezminiz
Charliezminiz
  • 512 posts
Posted 30 November 2009 - 03:56 PM
hi all, on the ignition coil i cant remember what wires went were lol, i got the 2 spade connectors on, and the ht lead, but is there an earth lead or something on the otherside to the spade connectors?
cheers inadvance guys.
#2 lawnmowercrap
lawnmowercrap
  • 896 posts
  • Local Club: Small 'n' Mighty Mini's
Posted 30 November 2009 - 04:39 PM
You should have two wires on the + (positive) side of the coil, one for the rev counter and one is the live feed.
Then only one on the - (negative) side of the coil. This wire connects to your distributor and this is 'technically' where the coil earths.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 30 November 2009 - 04:50 PM
Actually thats wrong the tacho feed comes off the negative side of the coil. If the tacho wiring is fitted as standard then you will only see one wire on the negative the tacho wire spurs off in side the loom
Depending wether ballast or non ballast you should have
Ballast 2 wires going to the positive on the coil (white/yellow and white/pink) 1 wire on the negative going to the dizzy through the loom white/black
Non ballast will just have one wire on postive (white) and one on negative (white/black)
Edited by lrostoke, 30 November 2009 - 04:53 PM.
#4 lawnmowercrap
lawnmowercrap
  • 896 posts
Posted 30 November 2009 - 04:57 PM
^^^ Do aplogise lol
Edited by lawnmowercrap, 30 November 2009 - 04:59 PM.
#5 benmoffat
benmoffat
  • 347 posts
Posted 30 November 2009 - 05:00 PM
Sorry Charlie to jump in.
I have 4 wires on mine, 2 on positive and 2 on negative. What would the 4th one be for please?
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 30 November 2009 - 05:03 PM
what colour are they, it may be a tacho wire, I'd guess not all spur off inside the loom, they just do on the 89 / 90 models Ive dealt with.
#7 benmoffat
benmoffat
  • 347 posts
Posted 30 November 2009 - 05:05 PM
Id have to get back to you on colours, my cars not here, its a 1988 and does have a rev counter
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 30 November 2009 - 05:10 PM
I'd go with rev counter, probably find both are white/black on the negative.
