Brake Pipe Union Size
2 replies to this topic
#1 mayunmarlady
mayunmarlady
  • 23 posts
Posted 30 November 2009 - 05:50 PM
Hi,want to make my own brake pipes.What size ends/unions do i need for a 1994 Mini Cooper? Thanks
#2 Cooperman
  • 23,366 posts
Posted 01 December 2009 - 04:04 PM
They are all 3/8" UNF with 7/16" AF hexagons for tightening EXCEPT the ones which fit into the brake pressure relief valve which is situated on teh bulkhed. This uses METRIC threads - YES IT REALLY DOES! I think tey are 11 mm fine thread, so they ALMOST fit. I've seen 3/8" UNF ends in these metric holes which does neither component much good and, if un noticed could be dangerous as you may seem to get a seal.
Only Rover could design a safety-critical system in such a dangerous way.
#3 mayunmarlady
mayunmarlady
  • 23 posts
Posted 01 December 2009 - 07:26 PM
Thanks,I'll re-use the metric ones then. I think i would of assumed they were all the same and rammed em in! thanks for the life saving advise.
