Spark Plug Expert Please
6 replies to this topic
#1 steve and tina
steve and tina
  • 47 posts
Posted 04 December 2009 - 09:06 PM
I have a 1983 Mayfair but the engine has been changed at some point to an A+ 998cc
I have today replace my plugs leads cap etc and noticed the plug I was given toay are different to the ones I took out
The car was running with NGK BP6E S
But I was sold today NGK BPR6E
Question is does the S make any difference or am I worrying over nothing
Thanks Steve
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 04 December 2009 - 09:10 PM
I think the more important part is the R after the "BP", this stands for resistor. Do you know if you have a ballasted coil....?
#3 steve and tina
steve and tina
  • 47 posts
Posted 04 December 2009 - 09:14 PM
No sorry no idea is there an easy way to tell which is which
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 December 2009 - 09:27 PM
It doesn't matter anyway, resistor plugs are nothing to do with ballasted ignition. Resistor plugs have RFI supression built into them.
The S means it has a standard end configuration (2.5mm copper core, single ground electrode). I can't imagine why new plugs would not have a code for the sparking end.
The B means it's the same thread and socket size, the P means it is a projected nose plug, the 6 is the heat rating (right in the middle of the range) and the E refers to the reach of the thread.
#5 steve and tina
steve and tina
  • 47 posts
Posted 04 December 2009 - 09:36 PM
Thanks for the info very interesting
#6 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 04 December 2009 - 10:50 PM
My 1990 Mini Cooper has electronic ignition and therefore I use NGK BPR6ES spark plugs, because I'm told the 'R' stands for resister which is suitable for cars with electronic ignition and that resister stops interference on the radio/stereo.
I can't imagine it'd do much harm to a Mini with points and a condenser, but you may get a weaker spark as a result?
Oh and a 1983 Mini Mayfair would have been equipped with an A+ engine as standard.
#7 Sherlock
Sherlock
  • 654 posts
  • Local Club: Mini Register
Posted 05 December 2009 - 12:21 AM
My 998 runs on Champion N7Y or RN7Y, ('R' meaning resistor) it makes no difference to the performance or emission readings so everything must be burning ok, as Dan said it is just a built in suppressor, I suppose ideally you could run them with copper core HT leads.
