(I don't really have one big freaky eye!)
So I thought its finally time I started a project thread.
I've been working on my Clubman for the last year or so, but didn't really have a lot to show for it up until now.
Firstly, heres my planned finished spec:
Body
Clubman with Zeemax bodykit (the old style one), painted Spectra Blue Mica
Angel eye headlights
Clear rear lenses
13x7 Superlites
Shaved door handles
Some kind of keyless entry system
Silver grill (with the GT badge)
Engine
1380 A+, built very similar to the one in the Minifilms 1380 engine builder DVD
Worked Cooper head
Standard gearbox
Suspension/brakes etc
New brake lines + braided lines
Drilled/slotted front discs with greenstuff pads
Maybe twin tanks (if I can find a right hand tank for a reasonable price!)
Powdercoated subframes
Fully rebuilt suspension with mostly new parts
Minitastic fast road spring kit with hi-los
GAZ adjustable dampers
Solid front subframe mounts
Standard rear mounts
Interior
Leather front seats
Originaly fibreglass dash, not a standard aftermarket one
'New' gauges, classic Smiths set with the dual temp/pres gauge
ICE/Security
SMS paging alarm
Optima battery
Uprated alternator
Fully redesigned wiring system
Aircraft circuit breakers and aircraft annunciator system to replace fuses and dash lights (I'm a pilot, hence the aircraft bits!)
Alpine headunit - one of the ones made for the iPhone
Alpine MRD605 amp - 675WRMS
Alpine FRV-545 (I think thats the model from memory) 175WRMSx4 - seriously, thats from the test card!
2xAlpine 10" DVC Type R subs
Alpine 6x9 Type R in the rear sides
Alpine 6" Type R in the doors
This is a 2 seater ICE mobile! The subs and amps will be built into the rear seat area
Probably heaps of other things, but those are the main bits that come to mind at the mo
So anyway, on with the progress.....
I originally bought a non running 1978 1275GT for NZ$1000 (I'm in New Zealand by the way!)
I wasn't too concerned that it wasn't running, as I was planning to rebuild it all from scratch anyway, I just needed a basic starting point. As a bonus is came with a DHLA40 Dellorto carb which is worth a few hundred bucks by itself, sweet!
The body was advertised as being 'rust free and fully prepped ready to paint'. But as with most things this wasn't completely true. It had rust in the passenger side floor and around the bonnet sill. The engine bay had a bit of rust as well, and the primer looked a bit shady.
I started by stripping it back to a bare shell which took a fair amount of time and garage space. I sent the subframes off the get sandblasted and powdercoated, the front was in good nick but the rear one had some rust which wasn't ideal. Managed to get a few more rear frames and came across a good one eventually - back to the powdercoaters!
I hadn't started on the body repairs yet, which was lucky, as I came across a mint shell on TradeMe (like Ebay, but way more popular over here) for only $400. The owner had spent 4 years working on it, had primered it all, and said it had absolutely no rust at all - he just didn't have time to finish it. So I grabbed a mates ute and headed across country to pick it up. Much to my surprise it was perfect! Not a single speck of rust, and a bargain price.
So that shell came home with me, and the old one was sold off on TradeMe, saving me a lot of work! Heres the shell as I bought it - complete with doors, bonnet, and a bonnet scoop! He'd sprayed a 'guidecoat' to sand the thing smooth, but it was a pretty damn thick guide coat! Also the roof and a few bits were an ugly crimson color, so that had to come off. Unfortunately I'll be using Acrylic Lacquer, and these bits were Enamel so I couldn't just spray over the top (the 2 types aren't compatible)
I put the shell on a small trolley, made it nice n easy to move around!
Those seats are from an MR2 which I'd planned on using, until I got some muuuch better ones, as I'll show in a later post.
Thats all for now, I'll get some more photos on later with more info on what I've done so far
