Mini Not Charging - No Alternator Light
Posted 07 December 2009 - 06:12 PM
I got in my car to drive home from work and noticed the alternator light didn't come on. It started fine but as the journey went on the battery started draining until it conked out completely with a flat battery.
I assumed a loose connection was the cause but couldn't find anything.
Any ideas?
Thanks.
Posted 07 December 2009 - 06:23 PM
If you have a voltmeter, turn the ignition on and check the voltage at all three terminals of the alternator plug. They should all read approx 12v. If the small wire is 0v, your bulb has blown.
EDIT: Forgot to mention, Check this with the ignition on!
Edited by cobblers, 07 December 2009 - 06:32 PM.
Posted 07 December 2009 - 06:47 PM
Any other suggestions?
Posted 07 December 2009 - 06:49 PM
Posted 07 December 2009 - 07:03 PM
What I can say is I just had the breakdown fella have a look who told me the alternator was fine, no issues (it's fairly new so didn't think it was that anyhow). He was pretty useless though and the best he could suggest was 'some fault in the electrical circuit'...
Edited by lam, 07 December 2009 - 07:05 PM.
Posted 07 December 2009 - 07:12 PM
Posted 07 December 2009 - 07:13 PM
Posted 07 December 2009 - 07:57 PM
I'm in a real dilemma with no real answers.
Posted 07 December 2009 - 08:15 PM
With the ignition on, using a short piece of wire, connect the small terminal to earth and see if the ignition warning lamp comes on.
If both these tests are OK then the alternator is at fault.
Posted 07 December 2009 - 08:29 PM
As he suggested, with the ignition on, you should find voltage between earth and each of the pins in the alternator plug. If you do not find voltage on each of the pins in the plug, you have a problem somewhere other than the alternator. If the big wires are not "hot" they may be broken in the plug or on their far ends (check the starter solenoid in particular). If the small wire does not have voltage on it, look for issues both at the alternator plug AND perhaps at the ignition switch. When the ignition switch is in the run position, power is supposed to flow from the switch, down a white wire to the warning lamp, then from the lamp along the small wire (brown/yellow ?) to the alternator plug.
If you find voltage on all the alternator plug wires, look for problems IN the alternator itself.
Posted 07 December 2009 - 08:33 PM
Posted 08 December 2009 - 10:11 PM
Posted 08 December 2009 - 10:24 PM
Firstly checked all wires, found a small one in the alternator to be loose, so re-attatched it, all earths are in perfect condition.
Ignition on I get the red light, engine on, red light goes out. Battery won't charge though. Which led me to the battery being at fault. Although if I leave it on jump cables from another car it will charge up lovely.
If I run the car with nothing on, it will charge up a little bit. So If I go for a drive with nothing on, the car will charge up a little and be able to start itself again.
Edit: It's a 1985 mini, it's got a pug306 diesel battery
Edited by mini_mad69, 08 December 2009 - 10:26 PM.
