Amplifier required
Posted 17 October 2005 - 04:44 PM
Posted 17 October 2005 - 05:18 PM
Posted 18 October 2005 - 06:30 AM
Posted 18 October 2005 - 07:35 AM
Posted 18 October 2005 - 08:30 AM
Posted 18 October 2005 - 03:40 PM
Will the sub also take the bass from the speakers ive got at the moment?
Ed
Posted 18 October 2005 - 04:07 PM
Yoor other speakers will still get all the range of frequencies from the head unit.
I would still go for some speakers up front even if they are just standradard speakers.
Use something like this:
Clickety Click
Then the sound will be more even around the car.
Posted 18 October 2005 - 06:48 PM
Ed
Ps
Would the above amp be able to run the 2 6X9 subs?
Click me
Posted 18 October 2005 - 07:51 PM
ported boxes are generally larger than a sealed, if designed and built properly they can sound very good, i prefer the sound of a sub in a ported over a sealed any day but its so much harder to get right, hence the reason most people opt for sealed.
With small subs i'd put them in a sealed box anyway as they should perform better, pus there probably aint enough space under the bench to fit a ported box.
Posted 19 October 2005 - 12:33 PM
Ed
Posted 19 October 2005 - 12:45 PM
a sub pre out will only pass bass frequencies to the amp.
if you have pre outs you will need an amp with at least a bass pass crossover
you can get these from halfords or maplins for about 10quid if your amp doesnt have a built in function,
then really your shelf speaker want only high or at most mid bass running through them.
again from the fore mentioned stores you can get mid and treble crossovers
this will help your speakers preduce a much clearer sound and higher volume capacity
Posted 19 October 2005 - 12:59 PM
Ed
Posted 19 October 2005 - 01:01 PM
Ed
Posted 19 October 2005 - 01:41 PM
this will seperate tweeters, mid range and bass
or a 2 way will seperate bass mid/tweets.
Just connect to the speaker cable and it gives you seperate outputs for each part of the sound.
about £10 upwards depending on spec..
have a look at www.maplin.co.uk clicky just type in crossover into the search box.
