Auto / Manual Engine Difference?
6 replies to this topic
#1 Timmy Clubman
Timmy Clubman
  • 116 posts
  • Local Club: I've never seen the point
Posted 11 December 2009 - 09:21 PM
My poor little clubby needs a new engine :dontgetit: I now need ( yet another ) 1275
Im having trouble finding one localy as a manual - so the question is, could i use an auto
engine instead or are the gearbox bolts spaced differently?
Or is there any internal differences ( crank ect. )
External fittings are not important, i dont mind doing a little fettling/modification/bodging ;)
If anyone could help me out here it would be greatly apreciated. Cheers
#2 Calman
Calman
  • 1,674 posts
Posted 11 December 2009 - 09:24 PM
Do wait for more answers first, but i think the auto engine has different oil ways. But either way auto's and manual's have different subframes. (Certainly on the earlier cars, pre 74)
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 December 2009 - 09:28 PM
It 'can' be used - but very considerable modifications and machining are required! The crank/rods/pistons and cylinder head can be used in your block if that helps.
#4 Brams96
Brams96
  • 2,308 posts
Posted 11 December 2009 - 09:29 PM
You can use a manual engine in an auto subframe (its wider) but not the other way round, and no the auto and manual gearboxes are different so cant be swapped on a manual engine or vice versa.
#5 mini.rich
mini.rich
  • 619 posts
Posted 11 December 2009 - 09:35 PM
Hi, its more than possible, I was planning on doing my clubby engine a while ago and came across this website, auto to manual block conversion if you click on 'Technical advice' and then down that page click on 'Engine' tells you all about converting the block. If you have acess to a miller etc its an easy job.
Hope that helps
Richard
Edited by mini.rich, 11 December 2009 - 09:38 PM.
#6 Timmy Clubman
Timmy Clubman
  • 116 posts
Well, it would have made things alot easier, but thats life
Never mind. Thanks for your replies people
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 December 2009 - 09:37 PM
You would need to be desperate to go through all that machining etc just to use an auto block!
