Footwell Lights
11 replies to this topic
#1 stormintrooper
stormintrooper
  • 2,072 posts
Posted 12 December 2009 - 02:48 PM
I was thinking of buying these
http://cgi.ebay.co.u...=item3a54bbb57b
to put under the dash pointing down into the footwells and operating on the courtesy light circuit so when the door opens they light up
what do you think?
also will it work by wiring up the negative of the LED strips to the door switches will that work and will they still come on when the courtesy light is switched on manualy without additional wiring? if not any ideas on how to do it?
#2 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 12 December 2009 - 03:47 PM
what do you think?
Yup, just give them a constant live, and earth into the door trigger switches. Flick the courtesy light switch and they should come on aswell, I know mine did.
#3 stormintrooper
stormintrooper
  • 2,072 posts
Posted 12 December 2009 - 03:55 PM
any pictures of urs lit up i want to know what it will look like
#4 mini_mad69
mini_mad69
  • 5,417 posts
Posted 14 December 2009 - 01:52 AM
I got a video somewhere, I've had a few different types, had UV lights but my mate kicked one and it broke. Then had white LED ones but they were too bright. Then I had these:
ur6wHmJmKYI
Now I've got nothing, not even the courtesy light as my rollcage ate it.
Started soldering up a load of Hyper bright blue LEDs, and will hide these all over the cabin.
#5 MiniMonty
MiniMonty
  • 1,802 posts
Posted 15 December 2009 - 12:55 AM
I think it's a class idea to have the footwell light up as the door opens - reminds me of my old Jag
which had a light under the door that lit up the area you were about to step into as you got out.
Now there's an idea...
#6 skaterava
skaterava
  • 1,857 posts
Posted 15 December 2009 - 01:58 AM
I'm planning on having a boot light that comes on when you open the boot >_< part of my install. I wanted footwell lighting but wasn't really sure where the tubes could sit, out of sight >_<
#7 stormintrooper
stormintrooper
  • 2,072 posts
Posted 15 December 2009 - 06:21 PM
dnt need tubes believe me..i just put a 9V on what i linked...and the battery had been used somewhat in my paintball gun and the led's were still VERY bright.....IMO tubes would be expensive and unnecessary
#8 lowandslow
lowandslow
  • 359 posts
  • Local Club: east coast mini club
Posted 15 December 2009 - 07:18 PM
just a tip but i put my footwell lights under my seats as the steering column gets in the way drivers side and didn't light up as well as the passanger side. >_<
#9 rover
rover
  • 61 posts
  • Local Club: Essex Mini club
Posted 14 January 2010 - 03:50 PM
Any photo's?
#10 stormintrooper
stormintrooper
  • 2,072 posts
Posted 18 January 2010 - 12:56 PM
none yet, i bought a 2nd courtesy light and tried putting it into the ashtray hole in the upper dash but the light is a tad to small for the hole so gotta rig something, neway the point of me telling you that is i have designed a way of adding the footwell lights to this aswell and therefore havent got round to fittin the lights as i need to make a way of gettin the courtesy light to fit first
#11 harryh733
harryh733
  • 220 posts
Posted 20 January 2010 - 07:24 PM
I installed some foot well lights into mine the other day, but I went for a cheap option which seems to work well, I just got 2 courtesy lights from the scrap yard and fixed them under the dash with cable ties (so I didn't have to drill anything :dozing: ) Then just wired them into a switch.
I like having them on at night time when driving as they give a nice dim glow.
Not sure how long it will last as I guess the lights aren't designed to be on for hours at time but for now I'm happy :dozing:
#12 Domlin
Domlin
  • 90 posts
Posted 21 January 2010 - 05:52 PM
I installed some foot well lights into mine the other day, but I went for a cheap option which seems to work well, I just got 2 courtesy lights from the scrap yard and fixed them under the dash with cable ties (so I didn't have to drill anything :P ) Then just wired them into a switch.
Not sure how long it will last as I guess the lights aren't designed to be on for hours at time but for now I'm happy :-
I had this idea aswell, so today i picked up a £9.99 Cold Cathode tube kit from Maplin... Unfortunately they are blue which im not too keen on, but i will see what it looks like...
I bought a toggle switch aswell (the On-off-On type) so i can have them on independently of the interior light, and also have them turn on when the driver door opens. I also really like the sound of the boot light, might have to look into doing that :errr:
Thanks,
Dom
EDIT: Wow i've been a bit silly... i had had a look around the internet and found that the inverters that cold cathode tubes use are quite dangerous... they are incredibly vulnerable to overheating and melting... I will most definetly not be using these in my mini. I shall stick to LED's or the good old fashioned light bulb.
I also found out that these inverters take the 12 volts up to 680, and im not very comforatable with that :P
Edited by Domlin, 21 January 2010 - 06:47 PM.
