Hesitation Problem On Accelerating
Posted 12 December 2009 - 11:40 PM
gazz
Posted 12 December 2009 - 11:47 PM
Posted 12 December 2009 - 11:48 PM
Posted 12 December 2009 - 11:54 PM
Posted 12 December 2009 - 11:56 PM
Posted 12 December 2009 - 11:58 PM
gazz
Posted 13 December 2009 - 12:49 AM
ignore that im an idiot ! just seen your carbs a hif38
Edited by Bakky, 13 December 2009 - 12:51 AM.
Posted 13 December 2009 - 01:39 PM
Posted 13 December 2009 - 07:21 PM
Gas analyser and rolling roads are great for modern cars but one that has been fiddled with needs the fueling to be experimented with. I believe that if your emmissions are near perfect then it's not getting enough fuel, it's a 50 odd year old design you know. The needle may be slightly wrong or the spring in the dashpot may be a bit weak for the motor.
I once had to stick two springs in a carb to get it to do as the engine asked.
Try and richen the mixture half a turn then a full turn and see what happens, you can allways turn it back out so nothing lost and all to gain.
Also I assume that all the wiring to the coil / dizzy is in excellent order with good soldered connections and sealed with sealant and points are right etc.
Last point is the vac advance, that must be free and working and the timing should be ok and not slightly retarded like some so called experts with rollin roads set it.
good luck with it.
Edited by minimender, 13 December 2009 - 07:23 PM.
Posted 13 December 2009 - 07:45 PM
Posted 14 December 2009 - 05:18 AM
Just warm it up in the morning, turn it off and let it sit, do other things like put on your shoes or something for a few minutes, then start her up and be on your way.
Posted 14 December 2009 - 08:58 AM
No rolling road needed.
